Clickity Click Click Click #4 Valvetrain
Old Oct 31, 2012 | 02:13 AM
C230 Sport Coup's Avatar
C230 Sport Coup + 2006 W164 ML350 + 99 Ford Escort RIP
So, 193K miles. 2.3L M111
Recently I start getting a clickity clack on #4 valves.
It comes and goes.
What could it be?
You don't adjust valves on these right? So what keep the proper clearance?
Are there hydraulic lifters?
Been living with a leak on the side of the head of #4 for a long time.
Just put a quart of coolant in every 1000-2000 miles or so.
Maybe less. Not sure if thats related.
I saw a vid online about adjusting the chain tensioner on M111.
Would this help?
https://www.youtube.com/watch?v=XsEcUpvoFlk
Or maybe I have a clogged oil passage? Should I flush the engine?
Usually read that's a bad idea.
Old Oct 31, 2012 | 11:47 AM
SeaCoupe's Avatar
2002 C230K, 2013 BMW 328, 2015 BMW X5
Eff, this is so not good! You can take the cover off to check the tightness (yes that's a technical term) of the cam journals at a minimum.
Old Oct 31, 2012 | 12:18 PM
Glyn M Ruck's Avatar
Super Moderator
The hydraulic zero lash followers/tappets on these engines rotate & if the noise comes & goes you might have a follower more worn in one spot than another or you might just have a tired follower or a gummed up follower. If you have a gummed up follower that is slow to react then a one-off 5K oil change may free it without mechanical intervention.
Old Oct 31, 2012 | 01:59 PM
SunnyRayToronto's Avatar
2003 C230 Sports Coupe, Paprika Metallic Red, Auto, Pano, Leather
Gummed up by carbon buildup,.... do you use Chevron Techron regularly,... MB recommended fuel injector cleaner added to fuel. Do you use SeaFoam,.... non MB recommended additive,... but SeaFoam added to fuel will clean fuel system,... SeaFoam added to engine oil will clean carbon from engine internal,... maybe a good idea to add SeaFoam just before an oil change,.... SeaFoam can also be added to throttle body,...
Old Oct 31, 2012 | 05:42 PM
Super Moderator
The gummed up is usually a very light varnish deposit. I really don't like Seafoam in oil or fuel. I don't mind once through down a vacuum line or similar.
Old Nov 1, 2012 | 02:53 PM
A tired follower? Is that like someone who spends too much time on Twitter?
ha...
seriously, can you splain it to me please? Is there a part that might require replacement? If I could just find a place to work on my car...arrgh.
Old Nov 1, 2012 | 09:34 PM
Super Moderator
The cam runs on item 26 Hydraulic lifter/tappet. If 26 wears it leaks & does not maintain oil pressure. Then it clatters because it can no longer maintain zero lash. You can pop in new ones by lifting the cams.
EDIT ~ In this context:
Hydraulic lifter, cam follower, tappet = same.
Attached Thumbnails Clickity Click Click Click #4 Valvetrain-m111-valve-assembly.jpg
Old Mar 9, 2013 | 08:51 PM
jimwv's Avatar
2004 c320
i had my engine vacc'd in other words, all the carbon removed by a mechn'k. disconnect the fuel system and run deturgent thru it, for an hour.
i still had the same nosie afterwards
