computer oil level check
Old Feb 28, 2002 | 02:08 PM
pixmation's Avatar
2002 Lexus IS300 5-speed
I was bored and did the oil level check. The computer displays "add 1 qt oil!" The car is 2 months a 1 week old with 2400 miles on it.
I assume this is covered by the included maintenance.
Old Feb 28, 2002 | 02:18 PM
benzomonterey
Guest
Posts: n/a
Mine has shown add 1 qt and add 2 qts before. Now it just say's perform service on time.
Try it again on a level surface it might change.
Old Feb 28, 2002 | 02:22 PM
Buellwinkle's Avatar
Mine said add 1qt sometimes and not others depending on the grade of the parking lot. I measured the oil with the dip stick when it said at 1qt and it was halfway between full and add. I asked the dealer about it and they added a 1/2 qt. This was at about 4,500 miles. Use the dipstick, it's more accurate.
Old Feb 28, 2002 | 03:00 PM
Brian Yee's Avatar
'01 CLK 55
From my experience, a very small deviation from level ground will register noticably different oil levels. Always attempt to take oil readings in similar surroundings for greatest accuracy. My garage has one level area while the rest of the space is on a 1-2%slope. I check the oil level before starting the car when left sitting overnite in the same level spot .
This method gives me the most consistent results especially if I'm monitoring consumption.
Old Feb 28, 2002 | 05:21 PM
MarkL's Avatar
2002 C240 6-spd (ret)
Originally posted by Brian Yee
... I check the oil level before starting the car when left sitting overnite in the same level spot .
Except, I think you're supposed to check oil when it's basically at operating temperature. You wait a few minutes for it to drain back into the pan. I suppose if you check it the same way all the time, it's consistent. But, you might get an early "low" reading since the volume will be lower when cold.
Old Feb 28, 2002 | 06:40 PM
Brian Yee's Avatar
'01 CLK 55
True. But I usually have the car filled to the mid point of the dipstick when cold. Testing at the same temp. and place in my garage gives me the best indication of consumption with the least variables. To date (CLK 55 w/ 7000 miles) I had no measurable signs of usage.
Old Mar 1, 2002 | 08:20 PM
patronus's Avatar
2001 C240 / 6-speed
"Now it just say's perform service on time."
This means that you have not waited long enough since turning off the engine to perform an accurate oil level check. It has nothing to do with servicing the oil on time (I think its a German-English translation problem).
Old Mar 1, 2002 | 08:30 PM
Fuzzo's Avatar
I didn't know there was a dipstick available.. again i speed read the manual and i specifically remember the salesguy telling me that the only way to check the oil was the computer...... i'm gonna have to check it out tomorrow morning.....
Old Mar 1, 2002 | 08:48 PM
Lynn's Avatar
Fuzzo, there is a dipstick on the four cylinder engine in the coupe. You sedan owners with your sixes are out of luck.
Old Mar 1, 2002 | 08:51 PM
Brian Yee's Avatar
'01 CLK 55
Ahhh, yes....The "post dipstick" generation. Though I can't believe you bought a brand new car and didn't bother to at least look under the hood to marvel at the beautiful German engineering.
Old Mar 2, 2002 | 12:27 AM
Hal H's Avatar
2001 CLK320
Oil warning messages
I had this similar message of: "stop engine now" and "perform service on time" with just 4,800 miles.
Oil level was fine and after a shut down & restart, everything was okay...when I brought the car in for warranty service, the trouble code indicated a bad oil sensor and I got an oil change and new oil quality sensor.
Old Mar 2, 2002 | 12:02 PM
Brian Yee's Avatar
'01 CLK 55
.....Just as the oil level indicator in my 911 sucks under the best conditions, (it also analog by the way)If you really gots to know, NOTHING beats the using the stick. Aside from checking it's function, I've never used the sensor to check the oil level in my CLK55....Call me paranoid.
Old Mar 2, 2002 | 02:41 PM
mdp c230k's Avatar
2002 c230k
OK, you're paranoid! Just kidding. Dipstick is a good idea because you can actually see the condition of your oil. Sensors fail, the finger never lies!
Old Mar 2, 2002 | 06:56 PM
Steve H.'s Avatar
2002 C230K Sport Coupe M6 C5 desert silver
In answer to the original thread question, mine also needed a quart at 2500 mi. Semi expected for normal consumption. Not sure if covered in scheduled maintanance. Kind of like filling up with gas. Be sure to check with your dealer as to the oil weight in the car. I got a surprise while I called my dealer as it was not Mobil 1.
