C230 Eletrical issue! Please help
Old Dec 8, 2012 | 10:30 PM
a3vw's Avatar
c230
Hi. I have a 2004 C230 sport. When I start the car none of the electronics in the car work. The only thing that does is the radio. None of the gauges works or interior lights, wipers, or anything. Is there a bad door latch? or can bus issue, or control module. Any ideas would be greatly appreciated.
Old Dec 9, 2012 | 04:51 AM
phister's Avatar
06 C230 SS 6spd
Have you checked the fuses? Might be bad relays or a SAM
Old Dec 9, 2012 | 03:45 PM
C230 Sport Coup's Avatar
C230 Sport Coup + 2006 W164 ML350 + 99 Ford Escort RIP
Yes, check all your fuses. Check the voltage on the battery. Got 12v? 13+ when running?
Low voltage causes systems to shut down. How old it the battery?
I had this happen recently after a big storm, everything came back after it dried out.
If fuses look good, and battery is ok, disconnect the battery and let it sit for 1/2 hour or even overnight, and reconnect. Check for moisture in the car...
Old Dec 9, 2012 | 08:58 PM
a3vw's Avatar
c230
I checked all of the fuses and they are ok. The battery is older but has 12 volts at rest. The other thing I forgot to mention is that nothing will wrok until I restart the car. Sometimes the first time i start it everything comes back but sometimes it takes 5 or 6 trys.
Old Dec 9, 2012 | 10:57 PM
Carsy's Avatar
2007 W204 220CDI Classic Sedan
If the battery is original then it is close to its use by date. I have read on this site that old batteries can cause these sort of symptoms in this car .ie The electrics in this car become problematic with a poor battery.
Old Dec 10, 2012 | 03:40 PM
Does the car run? Check the voltage running please.
How old is the battery?
If it runs, then disconnect the battery for an hour or so.
Then reconnect and start.
That resets everything and can bring a car back to life.
Did the car get wet inside?
When disconnecting the battery, make sure the key is not in the ignition.
When reconnecting, same thing and doors closed. That will reduce or eliminate any voltage spike since very little current will be being drawn.
Disconnect from the bolt on the ground side.
Quickly and firmly reconnect, avoid sparking and spikes.
Old Dec 10, 2012 | 06:43 PM
a3vw's Avatar
c230
I bought a new battery. So ill see if that does the job
a3vw's Avatar
c230
Oh and the car did not get wet at anytime
Old Dec 15, 2012 | 01:42 AM
Carsy's Avatar
How did you go ? Success ?
Old Dec 15, 2012 | 12:23 PM
a3vw's Avatar
c230
I just got it installed and the battery took care of the issue instantly! Thanks to all for the help!
Old Dec 15, 2012 | 02:28 PM
Carsy's Avatar
Its good to get the follow up as we all learn from your success.
