how much should i pay for a wheel alignment?
Old Aug 6, 2003 | 06:25 PM
kimchiFLAVA's Avatar
2005 Porsche Boxster 987
im going to my dealer on monday cause i think i got a wheel alignment problem since on my tires is really worn out on the edge
i called the one in richmond BC (canada) and they said they would take 1 hour to 1 hour and a half to do it and they charge 99 dollars per hour so thats about 150
the one in vancouver boundary said they would charge me 200 to 250 so whats the deal!?!?!
Old Aug 6, 2003 | 06:45 PM
Keyser_Soze's Avatar
C230 Komp Sedan - 2003
Installed H&R Cup Kits and did took my car to NTB Tire I was refered there, some dude there knows what his doin....charged me $89 bucks...they just put hte vehicle type year...in there system and it pllups out the price....
they give me all the range before after numbers...
Old Aug 6, 2003 | 08:00 PM
Rick's Avatar
C230K Coupe/Orion/C4/C5/CD/AMG Spoiler/V60/TeleAid, 2 MGB's
avg is around $90 with a reputable shop...
One place here charges $65, but they only do the front (yes, rear alignment is necessary too)
Old Aug 6, 2003 | 08:19 PM
Mike T.'s Avatar
2005 smart cabrio; 2008 Mercedes-Benz B 200
$50 CDN
That's what I paid for my 405 recently after I changed a worn tie rod end. And that was a PROPER alignment, where both tie rod nuts are loosened, the steering wheel is centred and each wheel is aligned individually.
You can tell a cheap alignment if you get the car back with the steering wheel off-centre. That means they've just adjusted one side of the car, which is an incorrect shortcut.
Old Aug 6, 2003 | 10:53 PM
moomeh
Guest
Posts: n/a
regular. $125
with coupon: $100
Old Aug 7, 2003 | 01:27 AM
ok so wait im not sure if even my alignment is off..
the right front tire edge is really worn but i drive my car pretty agressive when i turn right
so if it isnt and i go to my mercedes dealership and they take a look at it and say it is..how do i know there not just ripping me off?
they seemed to be lying about how long it would take at the boundary one how would i know if they would be lying about the whole alignmet itself?
o yah by the way thanks for the help
Old Aug 7, 2003 | 06:01 AM
Rick's Avatar
Take your car to a tire store and have them "CHECK THE ALIGNMENT"....to see if it's your car...or your driving. Most places use laser alignment racks these days. They can check it, show you a print out and you can then base your decision on that.
Old Aug 7, 2003 | 12:59 PM
totita's Avatar
C230 K
My dealer charges 1.5 hours for alignment ($150). My local repair shop recommended me to get an alignment from MB because apparently they use weights to simulate passenger load when the do the alignment. Can anybody very this rumor?
