Good Use for Ash Tray
Old Aug 11, 2003 | 11:14 PM
TNblkc230wz's Avatar
C320 Coupe
I finally found a good use for the ash tray. If you take it out and put it in the spare tire well, there is enough room in the cubby to hold a small, travel size kleenex and still close the door.
Old Aug 11, 2003 | 11:56 PM
lars's Avatar
05 CLK 500 cab
Sounds like a good tip. I'm going to try it
Old Aug 12, 2003 | 12:01 AM
session's Avatar
2007 VW GTI
This only works if you put it in the spare tire well?
Old Aug 12, 2003 | 04:32 PM
MarkL's Avatar
2002 C240 6-spd (ret)
For fear of re-starting a very old thread:
Some of us have electronic compasses in there!
Old Aug 12, 2003 | 06:19 PM
nukblazi's Avatar
people like me just want digital A/F and lambda value gauges in there...
Old Aug 12, 2003 | 06:57 PM
R4ND0M_AX3's Avatar
C230
I don't think the DIY-WB Lambda display I built a few years ago will fit there. I need a smaller project box.
Old Aug 13, 2003 | 01:50 PM
C320 Coupe
No, It's just a good place for it.
Old Aug 13, 2003 | 01:54 PM
C320 Coupe
What is Digital A/F?
I only do occasional autocrossing, so I have a bigger need to hold tissue on road trips.
Old Aug 13, 2003 | 02:24 PM
session's Avatar
2007 VW GTI
Air/fuel mixture readings.
Old Aug 13, 2003 | 02:30 PM
avlis's Avatar
2008 VW GTI
What is wideband lambda?
Old Aug 13, 2003 | 07:09 PM
lars's Avatar
05 CLK 500 cab
A lambda meter measures the output of an oxygen sensor, and provides an estimate of the air:fuel ratio. The perfect combustion(stoichiometric) air:fuel ratio, which is 14.7:1, has a lambda value of 1.0. The mixture gets richer when the engine is loaded, dropping the lamda value. I think a wideband lambda sensor has a bigger range than a stock oxygen sensor, which is designed just to keep the engine running properly
You have to be pretty devoted to performance tuning to carry one of these things around in your ashtray slot Personally, I'm going to stick with tissue.
