INEXPENSIVE DIY ADJUSTABLE REAR CAMBER ARMS
Thanks!
On the rod ends: The overall width is 1.370" & rod end width is 1.050".
Center of mounting eye to end of threads is 2-7/8"
So you probably have a adjustable overall length of around 11.5 to nearly 13 inches using the 9" swedge tubes.
Ex-factory there is only front and rear Toe adjustment for virtually all Mercedes 1968 to current models (and same with Chrysler Crossfire and 300C etc).
We saw the need therefore to manufacture precisely adjustable front Camber and Caster bushing kits with twice the adjustment range of these basic one setting offset bolts.
Then for the rear a Camber adjuster kit that unlike upper adjustable arms does not move the top of the tire outwards when adjusting to resolve premature inner edge wear which is an important factor to prevent tires scuffing outer fenders if wide profile tires/rims fitted.
Other advantage with K-MAC rear kits - unlike spherical bearings there is no harsh metal to metal contact and 20 years of proven experience - there's certainly no squeaks.
Also all K-MAC rear Camber adjusters include extra Toe adjustment which is essential to compensate accurately for the new Camber facility.
The K-MAC patented design front kits replace the 4 main suspension bushes - the unique design doubles the load bearing area thereby increasing wear life and also steering and braking response.
Similar design is used for the 4 main rear K-MAC bushings.
Result is precise single wrench front and rear (ongoing) adjustment to return vehicle to factory specs to resolve costly inner edge tire wear through altering height, fitting wide profile tires, load carrying, curb-knock damage and/or the advantage of being able to alter specs on track days.
http://k-mac.com/mercedes/
$860 is two sets of tires............
I would need to see some serious data to warrant a $760 price difference to achieve 1 degree camber.
I do agree with the general principle that the K-Macs seem out of line on price; wouldn't be the first time that an MB aftermarket price was higher than with other applications, though.
These DIY cambers have saved me around $750 over the K-Macs + $700 -$1000 on a set of prematurely worn tires. Didn't need the front K-Macs as the alignment bolts ($28 for 4 ea.) put me in spec perfectly. BAZINGA!
Had to do a double take on your avatar.
One thing I should mention, 12mm does not equal 1/2. The stock pivot bolts are M12 and the metal bushing for the Speedway tie rod end has a 1/2" bore. It may not matter but there is enough clearance that you can feel the bolt move inside of the bushing. Definitely not Mercedes tight.
I went to the Ace Hardware store and bought a 12" piece of brass tubing 1/2 OD .014" thick. I had to run a 1/2 drill bit thru the bushing to get the brass tubing to slide. The inside diameter of the brass sleeve is much much closer to 12mm.
Does it really matter? Probably not, the rear suspension is under constant load, you'll never perceived the slight movement (if any). If don't sleeve it make the installation easier because of the slightly larger hole. It bothered me though that is why I sleeved the bushings. It also provides a bearing surface between the threads of the mounting bolts and the bushing.
Use lots of grease on all threads of all of the fasteners and bushing surfaces.
