Strong smell of gas in the cabin on hot days?
Old Feb 27, 2013 | 08:23 PM
PersianW203's Avatar
2001 C320
I'm new to these forums, and I've been having this weird problem lately where if it's around 70-80 degrees outside, I can smell gas in my cabin...it doesn't happen all the time, but when it does, I have to pull all my windows down and it may turn out to be a serious problem? I'm not sure. What do you guys think?
Old Feb 27, 2013 | 09:04 PM
Moviela's Avatar
The gas tank is under the rear seat cushion. The top of the tank has two holes you can stick your fist through that hold the fuel pump and tank level sending unit. Of course they are sealed, but the seal may have come loose, or one of the hoses has rotted and allows fumes to be liberated in warmer weather.
Do get it checked at once. The smell of gasoline is a serious safety issue.
Old Feb 28, 2013 | 09:38 PM
2001 C320
Awesome, I just checked it out today and it seems like one of the caps was loose...tightened it and no more gasoline smell! Thanks for the fix!
