C320 ignition problem
Old Mar 7, 2013 | 02:51 AM
Venne-70's Avatar
C320 4-matic. Kawasaki ZZR-1400
Exclamation C320 ignition problem
Hi
I'm new to this forum. English language skills are not very good, but I hope that you will understand what I mean.
I have C320 and problem are next:
RMP speed to be high (over 5500 rmp / min) should be the next fault, cylinder 4 ignition failure. Fault will only cylinder 4
The fault is cleared when the car stops and starts again.
Attempts have been made to find fault as follows:
Experimented with two different MAF sensor to no avail.
Also tested a faulty MAF sensor, the fault code came MAF sensor.
This I wanted to test that other fault codes comes through
Spark plugs replaced.
Replaced ignition coil cylinder 1 from cylinder 4 Changed the plug wires to each other.
Secondary air injection shutoff valve cleaned and replaced with each other.
Changed the fuel nozzle cylinder 5 from cylinder 4.
changed the air and fuel filter.
I do not think that the problem would Camshaft Hall sensor, crankshaft hall sensor or Knock sensor,
because the fault is cylinder 4 It would be quite a coincidence that it hit the ground at the same cylinder.
Is the only chance that the ECU would be broken?
Old Mar 7, 2013 | 07:28 AM
Glyn M Ruck's Avatar
Super Moderator
Unlikely to be the ECU but not impossible.
Replace the coilpack on No 4 with a new one.
Fit new plug leads.
Check engine harness wiring to No 4 coilpack. Corrosion etc in connectors.
Check fuel pressure at the Schrader valve on the front fuel rail. It should be > 3.8 bar or 55 psi while cranking.
Good luck.
Old Mar 7, 2013 | 12:02 PM
Venne-70's Avatar
I have to remove the ECU wiring connector and watch if there's corrosion.
I try cylinder 1 coilpack and plug leads.
error is as follows: The cylinder 4 is dropped completely out of the ignition system.
Fit new plug leads.
tested in the cylinder 1 plug leads.
Coilpack connector ok. no corrosion
fuel pressure without checking, but I doubt it.
Need to measure it.
Thank you for your suggestions
Just came to mind have to change the spark plugs still cylinder 1 to cylinder 4 and experiment with possible transfer of the fault when cylinder 1
I remember the failure occurred after I had renewed the spark plugs. I do not believe in it, but there is a small chance that the spark plug had broken
I hope so
