Is front-center speaker grille magnetic?
Old Aug 19, 2003 | 05:59 PM
RA71325's Avatar
Question Is front-center speaker grille magnetic?
I am about to buy a small, active GPS antenna which has a magnetic mount and I want to know if it will adhere to the speaker grille on the top of the dash.
Does anyone know if it's ferromagnetic or aluminum or what?
(Yes, I know I could simply put a magnet on it and tell but, as a city dweller, getting to my car in the garage is not a simple task.)
Kal
Old Aug 19, 2003 | 06:59 PM
amdeutsch's Avatar
Administrator
MPG+ ROLFCOPTER
Re: Is front-center speaker grille magnetic?
Kal
Ok, just this once. Lucky for you I have to go get a beer anyway.
Glug, glug, burp. OOPS, sorry. Yep, its magnetic.
Old Aug 19, 2003 | 07:00 PM
Harris's Avatar
Kal
Does your car have Bose system?
Old Aug 19, 2003 | 07:02 PM
amdeutsch's Avatar
Administrator
MPG+ ROLFCOPTER
Re: Re: Is front-center speaker grille magnetic?
All C320s in the US come with Bose. Look at his sig.
Old Aug 20, 2003 | 01:11 PM
RA71325's Avatar
Thanks. I owe you one (beer, that is).
Old Aug 20, 2003 | 01:56 PM
Harris's Avatar
Re: Re: Re: Is front-center speaker grille magnetic?
Ohohoh.....lucky Americans!!!
Old Aug 20, 2003 | 02:42 PM
MB-BOB's Avatar
Admin Alumni
See Garage
Kal
Kal, tell us more about your GPS system. I'm thinking about getting an aftermarket unit that would sit in the ashtray area, but don't know much about antenna requirements, placement of antennas, etc. Are you intending to run your antenna wire behind the dash to the speaker grill area?
Old Aug 20, 2003 | 02:55 PM
RA71325's Avatar
The GPS I bought is a Garmin iQue 3600 which is a combination GPS/PDA. It does auto-routing with voice and graphic guidance.
While you can use it as it comes, battery life is very short with the GPS function enabled and the built-in antenna wants to be placed high on the dash where it is difficult to see and/or blocks driver's view.
My plan is to add the Gilsson external active antenna (2.2"(L)x 1.8"(W)x 0.5"(H) which should magnetically adhere to the speaker grille where it approximates the windshield. Reports state vast improvements in reception with this. The iQue itself will be mounted at the empty space below radio head unit and a short power lead will go to the cigarette lighter.
I do not plan to build in or hide any of the wires since the iQue will be removed for other uses and the car is leased. The antenna and power adapter can be stored in the covered ash-tray compartment.
While I chose this one for many reasons, alternatives to consider for this application are the Garmin GPS V, Garmin StreetPilot III, Garmin 2610 and the Navman iCN630. All of these are less than $1kUS, autorouting and removeable. For permanent installation, there are many other options.
Old Aug 20, 2003 | 03:49 PM
tifosiv122's Avatar
SLS AMG | S65 AMG | GL550
Here is where I placed my GPS...works perfectly...its metal, so the GPS stuck fine.
Erik
Old Aug 20, 2003 | 05:08 PM
RA71325's Avatar
Erik-
I see the antenna but what's that stuck to the windshield? Doesn't look like any GPS I've seen. :p
Old Aug 20, 2003 | 05:26 PM
tifosiv122's Avatar
Erik-
That's a Cobra radar detector.
Erik
