How to install SEQ Hydraulic Pump ?
Old Apr 10, 2013 | 05:44 PM
cheickcompaore's Avatar
mercedes C220
I live in West Africa (Burkina Faso) and i have a 2002 Diesel C220 sequentronic. Few weeks ago it started not shifting gears and board showing "O" when i accelerate and stop. I have to change fuse 58 before i can shift gears. Took it to a mecanic and had it checked. Result came out with low pressure of hydraulic pump and one glow plug. Bought new hydaulic pump part number A2095530201 from France and mecanic installed but it wont shift gears at all. I do not think mecanic knows how to deal with as it is his first time to deal with this type of problem. Please help. I need step by step installation process of the hydraulic pump.
Thanks,
Omar
Old Apr 10, 2013 | 07:36 PM
Glyn M Ruck's Avatar
Super Moderator
There is very little knowledge of the Sequentronic transmission on this forum. It was not available in most of our markets. You require a Star DAS at a dealer to set it up.
https://mbworld.org/forums/c-class-w...ghlight=vakity
Good luck.
Old Apr 11, 2013 | 06:57 AM
mercedes C220
Thanks Glyn,
Please keep me in mind if you do get anything on sequentronic electrical parts remove/install procedures. Thanks again for your reply.
Old Apr 11, 2013 | 07:03 AM
Super Moderator
Will do ~ You need to get that transmission onto a Star dealer computer to set up all adaptions. There is no other way to get the TCU to recognise everything & operate properly.
Old Apr 16, 2013 | 10:37 AM
mercedes C220
Hello Glyn,
Problem resolved, mecanic had DAS XENTRY 2010, he did the set up himself. Took him a while to figure it out since he claimed it was his first time to deal with SEQ. Thanks for your help and thanks to the forum. Will stick around and keep in touch.
Brgds
Omar
