Replacing Filters
Old May 7, 2013 | 10:32 PM
mis3's Avatar
2004 CLK320
Replacing Filters
I myself drive a w209 and although I am not a DIYer, I do change my air filters and pollen filter myself. My friend has a 2006 C230 Sport Sedan. I believe it has a 2.5L V6.
In my w209, the pollen filter is above the battery. Where is it in the C230?
I went to Wiki, the air filters for the C230 are housed inside the engine cover. For my w209, to remove the engine cover, I just lift it upward from the engine. How about C230?
Old May 8, 2013 | 12:24 AM
VVF's Avatar
VVF
2005 C230K(sold), Mk7 Jetta
1) https://mbworld.org/forums/c-class-w...placement.html
2) https://mbworld.org/forums/1226647-post7.html (similar on M272)
Please use search.
Old May 8, 2013 | 10:15 AM
mis3's Avatar
2004 CLK320
OK. The pollen filter is in the same location of my w209.
As for the air filter, I don't even bother to remove the front piece for my w209. I just lift up the whole engine cover.
Wonder if this would work for the w203 V6.
Old May 8, 2013 | 12:23 PM
Glyn M Ruck's Avatar
Super Moderator
Yes - Just pull off the engine cover/airbox. Make sure you clip it down firmly over the MAF when you replace it.
Old May 8, 2013 | 01:36 PM
mis3's Avatar
2004 CLK320
OK. The same for a w209. Thanks.
