Idling rough on first tank of gas?
I noticed that when I took a test drive on one in Redwood City. Does the idle smooth out? Is it rough as you drive it around town?
Reformulated gas has additives (MTBE) that cause it to burn quicker and thus hotter. The thought being this will assist in reducing emissions, and in turn, pollution. You probably already know about MTBE being from CA, but I just mentioned it in case you weren't familiar with what I was talking about.
Do you suppose the free tank from the dealer was less than super?
Remembering the frantic horror stories on this forum from others who introduced 87-89 octane by mistake, it didn't take long for the system to start throwing fault codes and so forth. I wouldn't think that the dealer would volunteer for such immediate customer disatisfaction.
On the other hand, there have been an equal number of posts from those questioning the inherent roughness of the 2.3L engine.
You have a beautiful car (from the pix in the "delivery" thread). I'm sorry you're having the problem. I suppose it's possible they sent the "new valet guy" to the station to get your gas, and they forgot to tell him what to get. Anything can happen. But it IS printed "PREMIUM FUEL ONLY" on the fuel filler cap.
STP, Castrol, Pennzoil all make very good products.
(and just a side note: Cam2 Racing Gas is the only national brand that has "High Octane" gas rated at 98 Octane...so I don't know what they sold Timmy)
I find it difficult to believe that a MB dealer would send you off with less than 91 octane. Afterall, all non-diesel MBs in the US use 91 octane, don't they?
I actually got reprimanded for putting premium in a $45,000 SAAB... no joke.
(and just a side note: Cam2 Racing Gas is the only national brand that has "High Octane" gas rated at 98 Octane...so I don't know what they sold Timmy) [/B]
nuff said
in case you're wondering yes I am prior military service.
get on with it slackers, I didn't complain about the features of my HUMMV even though it was made by the lowest bidder.
MB-BOB, I have to agree w/ DasMafia. When I bought my Passat, I was given a full tank of gas. That car also "required" 91, and my salesman told me they "only have" 87. They couldn't have cared less...
HOWEVER...
Previous posts on this less-than-premium theme clearly indicate that mistaken introduction of lesser octane gas in a current production MERCEDES-BENZ almost invariably results in NEAR IMMEDIATE MALFUNCTION CODES from the system. Thus, I wouldn't think it so easy for the dealers to get away with this stunt, given the apparent sensitivity to less than 91 octane.
If MB dealers played like they were Saab/VW dealers on a wholesale basis, I would think every third thread on this forum would be about this subject, since we all would be having malfunction codes or "Check Engine" lights screaming at us within a day or so after delivery. Since this is not the case, I'm concluding that this is a sporadic problem, at worst, meaning that the vast majority of MBs are delivered with 91(+) octane, as intended.
Does that make sense?
I'm sure I read somewhere in the literature that the software can control for knock on each cylinder individually. I'd guess that all it does is back off the timing, and maybe even let up on the throttle under a severe condition? Wouldn't surprise me if that brought up fault codes... but if the system is doing it's job it shouldn't hurt anything. Basically an electronic slap on the wrist. Once the octane is changed it should go back to business as usual.
On a related note I'd be leery of adding octane boosters to anything with an OBDII emissions system. Maybe I'm being overly paranoid here, but not knowing what chemicals are in the booster I wouldn't want them running past the sensors. They're not the most robust parts out there.
I think Alicia Silverstone said it best when she said, "Whatever."
One thing we will not tolerate here are personal attacks on other members.
Enough said.... I think we all get the point.
Yikes Wyatt! Too much caffeine? I think your quote: "yes I am prior military service" pretty much says it all. Nothing against the military--I've got plenty of friends in the service, I just think it's amusing that you use it as an excuse to spew venom and testosterone (to say nothing of bad grammar.) I don't really feel I need to defend what I wrote--for me $32,000 is a lot of money, and I want to make sure that my car is operating normally. My thread about the speed-sensitive volume is a ditto. The whole POINT of this board is for owners and prospective buyers to educate one another about these incredibly complex vehicles. That seems to be lost on you.
I think I'll just go back to lurking. Prior Military Service is in reference to the Sir Yes Sir.
https://mbworld.org/forums/showthrea...ghlight=octane
Trying to keep it constructive...
Spyke, I've not experienced this problem myself, but the previoius threads (on the older forum) mentioned the "Check Engine" light as the first sure indication that you have a problem when degraded or lower octane fuels are used. Yes the system tries to compensate, but apparently the light remains on until you introduce good gas... then it eventually goes out.
Of course, the "Check Engine" light can mean several things in addition to bad gas. But on a brand new car, the Teleaid advisors seem to indicate bad gas as the first diagnosis (whether appropriate or not).
defective MAF (Mass Air Flow sensor) or its related electrical harness - this is a common problem on late model cars
or -
a defective coil pack. Since I don't have the 2.3 K engine, I don't know exactly what kind of ignition coils are used in your application...
When my car was in for warranty service (different issue than yours) one of my 6 ignition coils died on the technician while they were checking out the symptom I had complained of. My V6 engine uses 12 plugs and a phased-spark ignition.
I got a call from the service advisor asking if I had rough idle symptoms (which I hadn't) and they discovered this, it was found that a coil had failed during their testing.
So - watch this symptom. I haven't heard of anyone else having rough idle/ uneven idle symptoms like that. If it goes on long enough, it can foul the catalytic convertors or the EGR system.
