Rough Start and Vibration
Old Jun 11, 2013 | 04:19 PM
TheOnlyBaleki's Avatar
2006 C280 4matic
I've noticed my car starting a little rougher followed by a slight vibration until the car warms up. Once the car has been running for a few minutes then it starts and idles fine. The CEL isn't on. I changed the plugs a few months ago and torqued them to spec. Any ideas?
Also, does anyone know the part numbers for the driver's side plastic turn signal in the mirror, as well as for the outside pillar covers for the same side. I made the mistake of parking on the street and a drunk dude on a bike swerved against my car. I have to get the glass replaced too.
Thanks.
Old Jun 12, 2013 | 03:48 PM
karansavjani's Avatar
Mercedes C200
Did you resolve this as i have the same problem?
Old Jun 12, 2013 | 04:18 PM
PeteyV's Avatar
W203 C230, W210 E350, W166 ML63
I also have this problem. Never was resolved even after multiple visits to dealership under warranty.
Old Jun 12, 2013 | 04:45 PM
offdepp's Avatar
1998 slk 230, bmw 135i and x5
hello
one of the other forums was talking about this too. i read the whole thing all million pages ( just kidding)
well it seems to come down to the wrong plugs.
the person in the thread changed to pulstar plugs and new wires. they also talked about leaking head gasket.
good luck
Old Jun 12, 2013 | 04:54 PM
2006 C280 4matic
I replaced with OE plugs. I've read some things about wires and coil packs. Is there a way I can check them rather than buying a full set?
Old Jun 13, 2013 | 10:00 AM
offdepp's Avatar
have you check for codes? is the car misfiring? if so you can see which cylinder it is and move the coil packs around and see if the misfire move with the coil pack. the spark plug wires are not expensive.
this link might help too
http://www.benzworld.org/forums/w163...l-packs-2.html
Old Jun 13, 2013 | 10:02 AM
Crna Mechka's Avatar
12 E350 4Matic Sport
Usually good practice that when you go to replace the plugs for the first time, you also replace the wires and coil packs. I'd start there.
Old Jun 13, 2013 | 10:19 AM
2006 C280 4matic
offdepp - I haven't checked for codes because no MIL is shown on the dash. I'll borrow a code reader and see if anything has been stored. I've read that vibration can be caused by a misfire but I guess until I get it scanned I won't know which cylinder.
crna - I was under the impression that the m272 engine only had coil packs and no 'spark plug wires'. Could you maybe post a link to the wires you mention?
Old Jun 14, 2013 | 10:40 AM
offdepp's Avatar
let me understand that you have a 2006 c280 ? how many miles
Old Jun 14, 2013 | 11:08 AM
offdepp's Avatar
http://www.mbpartsworld.com/showAsse...tring=ignition
here are to parts number for the coils 0001502780 or 0001501980
Old Jun 14, 2013 | 12:27 PM
Baleki - you may be correct. I was thinking about the M112. Check them coil packs though.
Old Jun 14, 2013 | 01:35 PM
2006 C280 4matic
Thanks for all the replies.
Yes, 2006 C280 with 124.5k and M272 engine. Thanks for the link and info. I'll update when I get a chance to scan for stored codes and go thru the coil packs.
Old Jun 14, 2013 | 01:48 PM
Glyn M Ruck's Avatar
Super Moderator
Make sure that the airbox is clipped down tightly over the MAF at the rear. Frequently the cause of the MAF hunting on the M272. Also happens but less often on the M112.
