W203 2007 fuse chart anyone?
Old Jul 23, 2013 | 08:24 AM
Jus call me J's Avatar
S203 1.8
Hi Guys,
I am having trouble identifying where the rear wiper fuse is. Does anyone have a fuse chart please?
Also I can't even locate the dash fuse box. Is there something I'm missing? In the user guide it says drivers's side, in the side of the dash under a cover. I popped the cover off on the left hand side of the car and cannot see anything under there???
I'd appreciate any links or step by step guides...
Cheers...
Old Jul 23, 2013 | 12:21 PM
tommy's Avatar
2004 Civic Si. FWD for the Win!
Hmm, maybe you're misreading which cover it is. When you open the driver's side door, it's the cover that is at the very end of the dash, that is hidden when the door's closed. Sounds like maybe you're popping the cover under the dash instead.
Once you locate it, there's a little indent, grab it and pull outward from the side that's closer to the cabin - the hinge is at the side closest to the front of the car.
These threads will help you:
Locations of Fuse Boxes
Second Post for Link to Fuse Descriptions
Says it's #s 14 and 41 (hope you're not dislexic). 14 is in the rear trunk area fuse box, and 41 is in the just off the dash fuse box. Happy hunting!
Old Jul 24, 2013 | 02:56 AM
S203 1.8
Thanks very much for your help Tommy...
My car is a right hand drive as I am in the UK (English)...
I've only seen them on the left hand side (US driver's side) in videos...
I checked fuse 14 in the back, and it seems fine, also the wiper started to work again albeit slowly...
I have a feeling that the actual wiper motor may be on it's way out =(
Thanks again for your help...
