These damn wheels...
You cant look at the wheel with car jacked up like that. You have to remember your suspension is at full travel with it jacked up. The wheels are going to sit higher up on the suspension then where it is sitting in your pics.. to really test fit you'll want to either jack up the wheel to height it'll sit at when the car it's on the ground or place some boards under the wheel and jack the car down to see where it did in on the suspension.
There defiantly not the sound is up front and now I'm almost positive the bolts are loosening because I torqued them to 80 drove to work had to re torqe them because they got looser...idk why I ordered shorter but there the right size. My stock bolts came out of the back of the stock wheel 3/4 of an inch. Then the stock bolts came out of the new wheel an inch and 1/4. So that's a half inch difference. 1/2 inch into mm is roughly 13 mm. So 40 mm from the stock size minus 13 is 27. I ordered 27mm lug bolts and when I torque them they turn 6 or 7 times so I can't see how they are coming out
#32
No I ended up not needing them its close all around but not needed. There also flush with the fenders so I'm afraid if I did it would stick out. As for the cone seat lug bolts I got mine from http://otisincla.com/ this is where most everyone on here gets them from. Measure what size you need and call then they will tell you what size and everything they have good service
#35
so the bolts are definitely coming loose? torqued them before i left work last night to 80 all around. on the way home the bumping started. got home and was able to re torque them to 80... WTF i dont understand this. the things turn 6 or 7 times in there so there has to be enough thread. im using the same size lug bolt as factory except they are 27 mm instead of 39 and they are cone seat instead of ball (per wheel manufacture) anyone have any idea?
#37
yea i got 27 mm cone seat because thats what the wheel calls for..i have no idea why its doing this.. they turn 6 to 7 times thats more then enough to torque them in and stay there...
#38
Cameron, have you removed the front wheels to see if there are any signs of rubbing/wear? I know this might be a stupid question since they're MB replica wheels but, are the hub bores 66.6? Jacke the front up and put soem jack stands under the car and free-spin the wheels and see if you can find the source. Are all four corners coming loose or just the front? I know you said the noise is from the front but I can't remember if the loosening problem is also happening on the rear.
#39
#40
#42
Sorry it took so long idk why I never saw the email that there was a reply lol it's all good now ended up bringing it to a local guy he ordered me new lug bolts and I got the car lowered
#46
2012 C300 Sport 4MATIC (current) 2006 C280 Elegance 4MATIC (sold)
I don't really trust that factory jack. It's very smooth to operate, I'll give it that much but I still use a good 3 ton jack to lift this car up as they're pretty heavy. These MBs having a 31mm offset is so stupid, I'm having a hard time finding a good quality 16x7 or 16x7.5 rim that can accommodate my winter tires for next winter. 35mm offset is popular but it will be too far in.
