W203 Door Lock Alert Siren Beep Tone
Old Aug 23, 2013 | 12:59 PM
Preet's Avatar
E63 AMG W211 & W203 Sport Pkg
Has anybody modified a W203 to beep when the door's are locked or unlocked with the smart key, on a car that does not have a factory alarm option or does anybody have the location or the diagram of the relay that controlls the flashers when the door locks are locked or unlocked?
Old Aug 23, 2013 | 01:18 PM
bigspender101's Avatar
2003 c230k
You have to hook it up to DAS and get into the security settings.
Old Aug 23, 2013 | 06:22 PM
amdeutsch's Avatar
Administrator
MPG+ ROLFCOPTER
There are numerous posts on this subject. Hint; it has do to with a foreign country. Please search.
Old Aug 23, 2013 | 10:05 PM
SunnyRayToronto's Avatar
2003 C230 Sports Coupe, Paprika Metallic Red, Auto, Pano, Leather
Preet is cool,... I`ve meet Preet before,...
Oh,... and that foreign country is NOT Norway-Norwegian,... lost count of how many people asked for that Norwegian Door Lock Chirp!
STAR instructions for the "Netherlands Door Lock Chirp/Confirmation Tone" can be found in post# 8
https://mbworld.org/forums/c-class-w...lift-w203.html
Old Aug 24, 2013 | 01:35 PM
samaritrey's Avatar
Super Moderator
THE C350
also if you have a newer car I know the 05 can have the beep and keep the USA setting
Old Aug 28, 2013 | 01:01 PM
Preet's Avatar
thanks a lot for the input guys, but as I said my car does not have a factory alarm option installed, so my question is do I just need to add the siren or the entire module for it to operate and by the way I have had my car programed for the Netherlands Door Lock Chirp
Old Aug 30, 2013 | 02:05 PM
Preet's Avatar
anybody?
Old Aug 30, 2013 | 02:16 PM
tommy's Avatar
2004 Civic Si. FWD for the Win!
All of us in the US have the alarm, so we wouldn't be able to help. Unfortunately, you'll have to rely on your Canuck brothers.
Have you tried your local dealer? I'd imagine they'd be able to give you a straightforward answer if you're nice enough, and lead them on about having them do it.
Old Aug 30, 2013 | 05:55 PM
Isn`t the alarm contained in the siren,...
Anyways, to add alarm, you`ll need siren, bracket, tow sensor (connect to rear SAM). There isn`t a separate alarm module,... I just assumed it part of siren,... could also be in front SAM.
Old Aug 30, 2013 | 07:08 PM
Alswag's Avatar
2003 CL203 C320, 2002 W208 CLK320 cabriolet, 2012 A207 E350 cabriolet, 2011 X204 GLK350 4matic
It is possible to have your car beep at you when you lock it the hard way. You have to connect the relay for the headlights to the horn, but that means when your headlights go on, your horn will be continuously active.
Me and my mechanic tried it for ****s, turns out it's not a permanent solution.
You need the alarm siren installed into your vehicle to have the car beep back when you lock it. It's a pain, but it's doable.
Old Sep 3, 2013 | 12:44 PM
Preet's Avatar
does anybody have the diagram of the SAM of the pin outs?
Old Sep 6, 2013 | 12:47 PM
Preet's Avatar
:bump
