Power steering rack problem
I am having a problem with the power steering. Basically the power steering oil started leaking underneath the car. Yesterday I replaced the plastic boot on the power steering rack because it had a big cut in it. We thought it was leaking from that.
Then, I learned that oil should not even be inside of the boot. So I figure we have to replace the whole steering rack. The Mercedes tech said we can't take out the side arms on the rack to check if the rubber seals are good.
So my question is, can you just check the seals or do we have to repalce the whole rack?
Autozone is asking 490 with shipping minus 70 if you turn in your old rack. Dealer wants 1400 for OEM one. Do you guys know any reputable websites where I can purchase it ?
http://www.mercedessteering.com/
http://shop.advanceautoparts.com/web...011#fragment-1
I got a new rack and installed it today. Everything was working fine until coming home from the store. The steering wheel locked up and it didn't want to move left or right. Does anyone know why this would happen? Its still locked up, so it didn't go away.
It worked fine until we put in a new steering rack yesterday. Then when we test drove the car, we went to the store and on the way back it locked up and it was very hard to steer like the pump went out. Would this just be the pump or is there a different problem?
found a steering pump for cheap at http://www.buyautoparts.com/buynow/2...-00974_AN.html
Has anyone bought for them? Are they reputable ?
If you can jack up the front of the car to remove the weight off the front wheels, then how hard is it to turn the wheels? It should be fairly easy, almost as easy as with the PS working. If not, then maybe something in the rack.
I go back to the fluid -- what did you put in the car? These cars are VERY temperamental with fluids ... I believe Pentosin or Febi CHF 11S is the only fluid you should be putting in them. If you put in something else it's possible that the pump isn't able to push the fluid when it's hot, or that you wrecked either the pump or the rack by pushing the incorrect fluid through it.
I'm not an expert on PS here, so once you answer the question about the fluid others more knowledgable will hopefully chime in.
The first steering fluid we bought was from O'reilys. My dad said he needed steering fluid for 02 mercedes c230 and the woman gave him Valvaline power steering fluid... We used that one when we refilled the pump because it was leaking. After we replaced the rack to stop the leaking we went to the dealership and bought the OEM mercedes steering fluid. I believe that most of the Valvaline steering fluid was flushed out after we replaced the rack. So , that might be the problem.
There is a fluids expert on this forum -- Glyn Ruck -- who would probably know if this could have caused fatal damage to the pump or rack.
So we replaced the power steering pump and it did not fix anything.
I had a friend who is a tech come over and said that it was the SPS sensor, which do not apparently come with re-manufactured racks. However, I am not sure my 2002 c230 even came with the sensor. I went to autozone and returned the old one and had them ship me a new one while looking up the part with my vin number.
Hopefully it was just a bad rack they sent me. Does anyone know anything about this sensor and if it comes on our cars?
http://www.benzworld.org/forums/w203...ml#post5430708
You mentioned you replaced the power steering pump, but then go on to talk about the "incorrect" rack. Did you replace the rack as well?
Also, until someone who knows better chimes in, try this site -- http://www.mercedessteering.com -- and pull up your car. If I pull up mine (2005 C230) it shows two options for steering rack, with and without speed sensitive. On the speed sensitive rack there appears to be a third plug on the steering column post, presumably where you install an electronic plug or entire fluid valve to adjust fluid flow. If you look at the 2002 C230s, however, there is only one option that matches the non-speed-sensitive rack.
It worked then after turning the car off and coming back from the store it stopped working.
That is the problem we are dealing with now. We thought it might be a faulty rack or just need to reset the battery or something. We have a new rack on the way for a replacement.
Update:
My dad installed the new rack autozone sent us. The car works fine now and there is no problem with the steering. I believe the first rack was just a bad rack.
However, we are going to sell the car now and upgrade to a SUV. Maybe rav4 or otuback or something. Do you guys know how much the value is for it in the Virginia region? Its a 2002, and it only has around 100k miles. Thanks guys!
You can look into KBB prices, or peruse local craigslist posts.
Good luck!
Sorry to hear you're selling your car. You're just starting to have fun with it!
The car has been working for for 2 weeks and today the steering wheel locked up again.
This time we believe its the high pressure steering hose. The hose that connects steering rack to steering pump. When the car locked up we opened the hood and checked the hose and it was burning hot. Apparently it is not suppose to be hot at all. We let the engine cool down for a second and it startd working fine. So now we are trying to find one online. Does anyone know where I can find a power steering hose? No website has the right one.
Closest one I found was. http://www.mymercedesparts.com/parts...agramCallOut=3 Number 3
However, there is no clear picture.
Thanks guys.
Maybe there is some restriction (in the hose or in the rack) that does not let the fluid flow freely, and the fluid cannot be cooled because of that.
Anyone have a similar problem?
