Easy active TPMS retrofit
Rating: Thread Rating: 2 votes, 5.00 average.
Old Oct 18, 2023 | 10:27 AM
  #126
PARADOX_sf's Avatar
CLS 55 AMG P30, C32 AMG
Hi.
Today I've found that i am having OEM W203/W209 post facelift TPMS ecu (us spec) + a brand new wiring for it. If somebody wants to retrofit that option it is a complete kit, just tire sensors are needed. I can ship it worldwide.
Old Oct 18, 2023 | 10:30 AM
  #127
PARADOX_sf's Avatar
Originally Posted by E63007
I just located a video ( https://www.youtube.com/watch?v=6sYbluzI9zM) of the TPMS Sensor I had installed and it shows that it is indeed a Schrader 433 TPMS! I had assumed it was Siemens as that is what my EPC States for my 2007 E63, but when I called the Benz Parts guy I deal with locally (as I do when I need a part in a pinch, otherwise I order wholesale online!) I said I needed 433 due to my thinking that the AVIN HU I’m planning on installing being able to read any 433, (but I was misinformed about that by the “Tech” at AVIN!) so he provided me 4 (000-905-39-07) which turn out are Schrader after all! As such I think I can install the relatively easier to install TPMS system, am I correct on this?
If you buy these sensors as aftermarket part they have to be programmed for the specific application (car) that they are going to be used. Special equipment is needed for this.
Old Mar 12, 2024 | 09:55 PM
  #128
brb10711's Avatar
Mercedes G500
Hi. How were you able to program in the simulation mode!? The PDF instructions clearly show the simulation mode!
Old Jan 18, 2025 | 02:17 PM
  #129
MBruto's Avatar
W203 220 CDI 2004 FaceLift
To the poor with 2004 versions only!
Can't a CGW (Gateway) be introduced into the car that is updated and has the TPMS option?
How to make CGW prevail over EZS?
Old May 1, 2025 | 06:28 PM
  #130
TelmoChaparro's Avatar
C 220
Im in the same situation
I have everything installed i can see the sensor and values on Xentry, but i cant activate it because i cant acess CGW, or mine doesn't have it
12/2024 Model
You have already rated this thread Rating: Thread Rating: 2 votes, 5.00 average.
