Clunking noise while reverse slow speed on rear brake.
So I replaced my rear rotors and pads about three weeks ago.
I purchased below parts from tirerack:
- 1 set brake pads (akebono EUR873)
- Brake rotor (Centric High Carbon Plain 125 Series Rotor)
The installation went smoothly until a week ago, I noticed there was clunking noises when I drove backwards slowly. I can hear the clunking noise from inside too. It was not loud and happened only when I moved backward. The noise appeared when I tapped the brake and released. Everything seems normal when moved forward. No clunking sound at all.
I checked all the bolts (rotor, caliper) and the pin also looked perfect. Nothing wrong with it.
It does not affect the brake performance at all, but I'm getting annoyed with the clunking sound.
Anyone ever experience this issue?My first guess is the fitment issue, as this is an aftermarket pad.
Should I replace with the original pads or I can just use it until next brake job?
I believe my parking brake shoes works fine as they gripped perfect/normal.
If you think the pads are loose, then did you use MB brake paste on the back side and edges of the pads? And is the spring clip ok?
Also -- a long shot -- a wheel bearing? A long time ago my '66 Mustang had a knocking sound in the LF wheel ... turned out to be the outer wheel bearing.
