Body Codes
Old Sep 19, 2013 | 10:12 AM
amgcl55's Avatar
05 CL55 AMG
Body Codes
I have a short term access to the WIS-where are the body codes for the a/c -I cant seem to find them even with the WIS search- THX
Old Sep 19, 2013 | 06:32 PM
amgcl55's Avatar
05 CL55 AMG
I have searched for hours and never found Body Codes just engine codes.
Anyone have more info on a B1301 code for a 01 c320 with AAC
Old Sep 19, 2013 | 06:57 PM
Glyn M Ruck's Avatar
Super Moderator
These are all I can find in my records. Ask Movie where he found them in the WIS. These are MB only codes.
 B1000 HRA Headlamp range adjustment: Supply voltage of the control unit is too low (undervoltage)
 B1004 LCP Lower Control Panel: Control unit does not match vehicle type
 B1056 Automatic Air Conditioning: Problem in CAN communication with control unit DCM-RL
 B1201 Electric seat adjustment front left: Hall sensor front height
M27m3
 B1213 If seat memory installed: ext left rearview mirror voltage faulty
 B1214 If seat memory installed: ext right rearview mirror voltage faulty
 B1226 In-car temperature sensor (B10/4)
 B1227 Outside temperature indicator temp sensor (014)
 B1128 Heater core temperature (B10/1)
 B1229 Heater core temperature (B10/1)
 B1230 Evaporator temperature sensor (B10/6)
 B1231 ECT sensor (B11/4)
 B1232 Refrigerant pressure sensor (B12)
 B1233 Refrigerant temperature sensor (B12/1)
 B1234 Sun sensor (B32)
 B1235 Emissions sensor (B31)
 B1241 Refrigerant Fill
 B1246 PTS Parktronic: A42b1 (left outer sensor, front bumper) The plug connection has poor contact or is loose, or the sensor or cable is faulty
 B1310 Left/Window airbag sensor is defective
 B1315 Problem in Front passenger child seat recognition
 B1416 Coolant circulation pump (M13)
 B1417 Duovalve (Y21y1), left
 B1418 Duovalve (Y21y2), right
 B1419 Electromagnetic clutch (A9k1)
 B1420 Idle speed increase
 B1421 Pulse module (N05)
 B1422 Series interface (K1) connection to instrument cluster (A1)
 B1423 Switchover valve block (Y11)
 B1424 Activated charcoal filler actuator (A32m2) open
 B1425 Activated charcoal filler actuator (A32m2) closed
 B1432 Non-USA DTC
 B1459 Series interface (K2) connection to instrument cluster (A1)
 B1462 Wide open throttle (WOT) position signal diesel engines
 B1476 Airbag malfunction indicator and warning lamp is defective
 B1481 HRA: Part E2m1 (Right headlamp range adjustment motor) has short to ground
 B1489 HRA: Part E2m1 (Right headlamp range adjustment motor) has open or short to positive
 B1492 HRA: Part E1m1 (Left headlamp range adjustement motor) has short to positive
 B1617 Part E19/1 (Left license plate lamp) is defective
 B1618 Part E19/2 (Right license plate lamp) is defective
 B1628 Part E2e5 (Turn signal lamp) in module E2 (Right front headlamp unit) is defective.
 B1703 Intermittant No Start in AAM Immobiliser Module
 B1729 PSE Pneumatic system doorlock Control Module A37
 B1736 Navigation system's CD Player: Check General CD, Check CD data block, Flimsy CD data
 B1768 Faulty open data flap limit switch (0025) Front flap
 B1773 HRA: Zero position programming has not yet been carried out or is not possible
 B1850 Electric seat adjustment front right: CAN communication interrupted with DCM
