03' c240 cranks, but nothing else. help!
Old Oct 19, 2013 | 10:36 AM
MicG's Avatar
03' c240
Unhappy 03' c240 cranks, but nothing else. help!
I'm at a loss, I hope someone can help!
No problem starting the car, it cranks and runs fine. The problem is nothing else works in the MB. No radio, windows, speedometer, gas gauge. Basically nothing electrical inside. and also can turn the lights on if I turn the headlights of auto.
my autohouse says its' the key fob, called MB and they thinks it something in the ignition. At a loss and car in parking lot. Not sure what to do. Really can't afford to take it to MB right now.
Stranded
Old Oct 20, 2013 | 01:25 PM
corkshoppe's Avatar
Top Answer: 1
13's550/2000's430/13'gl63/'13's550/10's63
i would disconnect battery and do a reset, and go from there.
Old Oct 20, 2013 | 06:20 PM
MicG's Avatar
03' c240
Thank you corkshoppe, sorry to ask but how do you do a reset after I disconnect the battery?
Thank you again,
MicG
Old Oct 20, 2013 | 06:44 PM
Glyn M Ruck's Avatar
Super Moderator
Misread the problem
EIS or SAM trouble is likely. Get this car onto a Star.
Check all fuses & connectors in front & rear SAM
Old Oct 20, 2013 | 06:56 PM
Carsy's Avatar
2007 W204 220CDI Classic Sedan
Stranded
How old is the battery ?. These cars are prone to all sorts of weird symptoms when the battery is weak.
Maybe a battery load test & alternator check is in order.
Check this post:- https://mbworld.org/forums/c-class-w...ont-start.html
