popping noise from behind the ignition key area
Old Oct 24, 2013 | 10:35 AM
fmaalouf73's Avatar
2003 C240
2003 C240
heres my problem. Yesterday i turned on my vehicle and i heard a popping noise that sounded like it was coming from behind the ignition key area or maybe behind the radio. this lasts about 10-15 seconds then stops. Happened again this morning the same way.
Any clue what might cause this? I was thinking maybe it had something to do with the steering lock? or the vent motors?
thanks for your help.
Old Oct 24, 2013 | 11:53 AM
edgarinho10's Avatar
2013 UFO
Sounds like the stepper motor.
Look through this to make sure it's that;
https://mbworld.org/forums/c-class-w...g-hissing.html
Old Oct 24, 2013 | 12:59 PM
funnyent's Avatar
c230k
I have the same problem in my car, and like mentioned above, it's the stepper motors for the a/c vents. They're hard to reach so I've just learned to live with it and haven't really noticed it that much anymore.
Old Oct 24, 2013 | 03:28 PM
fmaalouf73's Avatar
2003 C240
thanks for the info guys.
I talked to my mechanic, he said that it could be anywhere from $206 to $609 depending which stepper motor is causing the issue. apparently there are several of these and the worse case scenario is having to remove the dash to get to it.
Does that sound about right?
Old Oct 24, 2013 | 03:41 PM
funnyent's Avatar
c230k
Yeah that sounds correct. I DIY a lot on my car, but I won't even attempt to replace my stepper motor that is broken because I don't want to take apart the entire dash. I found that playing with the air selector can make it less noticeable for a while (make it blow at your feet, then move it to defrost, etc.). Eventually you'll be able to get the flaps stuck in a different location and the clicking may be less noticeable (at least for me).
Old Oct 24, 2013 | 03:52 PM
fmaalouf73's Avatar
2003 C240
Thx. Ya i think I'll deal with it for now. It only lasts about 15 seconds before it times out.
Old Oct 26, 2013 | 11:50 AM
2013 UFO
That would annoy me enough to remove the entire dashboard if needed. I would say go for it. It's fun.
Old Oct 26, 2013 | 03:37 PM
samaritrey's Avatar
Super Moderator
THE C350
Yeah dash removal is so much fun you get to learn about what is under everything and waste a good weekend and a few 12 packs
Old Nov 1, 2013 | 10:51 PM
VVF's Avatar
VVF
2005 C230K(sold), Mk7 Jetta
What what what! How about this exercise?! :- ))
