Need help with amp
I have an aftermarket 250 watt DD audio sub in my 03 C230 and it usually works great. It's connected with an elf audio amp to my Pioneer double din and the amp is hooked up directly to the battery by 4 gauge wire. Usually it works great and is loud, but recently it only plays and about half volume and then randomly gets loud (usually when on the highway, or after running the car without the radio on for a while).
Anyone know why the amp is doing this - it seems starved for power but it's only a 250 watt system so I don't think this should be the case. I know capacitors are usually not needed, but would one or a big 3 upgrade help out? My battery rests at 12.6v when car is off and is showing about 13.4 when running.
Thanks so much for your help!
Tim
Hopefully someone out there can shed more light on this ...
In W203 cars there is an 8 gauge wire already in the trunk. A fuse can be added to an unused slot on the rear SAM and then wired to run any amp that can drive the speakers at a level that will allow you to stay in the car. 14 to 18 gauge is plenty.
The usual rules of good practice require good ground connection, usually an existing stud works well.
There are also thermal considerations. These tend to be class D amps which run cooler because they use switched transistors, but they have awful distortion and poor linearity compared to well designed class AB amps. I might use a class D amp for LFE or a subwoofer, but never for HiFi audio. The class D amps are cheaper to make, and often have poor thermal performance. While they are switching amps, complex sound waves force some transistors to operate in a linear manner and the heat quickly goes through the roof. Mounting of the AMP is critical to get good airflow over the heat sink. If you park in the sun, the AMP might already be at 140 degrees when you open the door. In this case, don't switch on the AMP until the A/C has time to work. Rather than the trunk, consider under the seat, there is A/C there.
Your battery voltage is fine. A capacitor would be as useful as teats on a boar hog.
Thanks again for your help,
Tim
