Weathertech mats for 4Matic
Old Nov 27, 2013 | 02:50 PM
yulc320's Avatar
C320 2005, Lexus SC430 2004
Hi, I'm new to this furom... Searched some floor mats threads but couldn't find an answer.
I wanted to buy weathertech Floorliner mats for my wifes2005 C320 4Matic. Unfortunately, they are not listed for the 4Matic (only the RWD). I asked the customer support if they would fit the 4Matic and they said no!
I wonder if it is true (that they won't fit) or if they said no only because they haven't tried them in a 4Matic???
Is the floor realy diferent in the 4Matic (vs RWD)???
Anyone with a 4Matic using/tried those and can confirm fit or not?
Thanks!
Old Nov 27, 2013 | 04:30 PM
marquisalley's Avatar
2004 C240 4Matic
I've been having the same problem man, been looking everywhere for all weather mats for my 4M but couldn't find any. Fortunately I called the Benz dealer in Syracuse and they do have all season floor mats that fit the 4M the best in my opinion, the only problem is the passenger side mat but it's not THAT BAD and they're not too expensive neither, roughly $120 I think.
Old Nov 27, 2013 | 04:38 PM
pa-hawk's Avatar
C280 4Matic
Back when I bought my 4-matic I also had looked at their mats and no, they won't fit. It is the front passenger side that has the fit problem. If you look you will see the transfer case bump out next to the console which is why that one will not fit, the others should. It seemed odd to me that the model most likely to be driven in the sloppy winter conditions is the one they do not make a mat to fit. I just abandoned the whole mat thing and figured that when the origional mats got beyond the point where they could no longer be cleaned up I would just buy another set of origional equipment carpeted mats. My dealer did stock the weathertech mats at the time and they were more than a new OEM set of carpeted mats. So far after four years of PA sloppy winter weather I have had no problem cleaning up the origional set. I also had contacted weathertech at the time and they confirmed that they did not make ones for the 4-matic. After driving the 4-matic on bad roads for four years I can say you will be very pleased with it. The mats will be a minor problem you will soon forget.
Old Nov 27, 2013 | 05:40 PM
yulc320's Avatar
Thanks for the info PA-Hawk!
We do have bad roads here too in Quebec!! For me, AWD as been a must for many years now... Had several Subarus (including an SVX), G35x and now the C3204M.
Old Nov 30, 2013 | 10:26 AM
Crna Mechka's Avatar
12 E350 4Matic Sport
OEM rubber mats by MBZ fit just fine. Sure the bump on the passenger side is annoying but manageable.
Old Nov 30, 2013 | 11:41 AM
corkshoppe's Avatar
Top Answer: 1
13's550/2000's430/13'gl63/'13's550/10's63
weather tech will custom make them if its not listed, i just bought a set for my vw, it wasnt listed and they made 1!
Old Feb 18, 2019 | 07:16 PM
jvakos's Avatar
E63 SL55 996TT C5Z06
old thread but wanted to see if anyone knows.....since nobody makes a W203 4MATIC all-season weather mat that has the passenger side mat curved to accommodate the transfer case with the 4MATIC, does anyone know if these W211 4MATIC all season mats would fit? the passenger front mat appears to be contoured to accommodate the transfer case "bump" which is what i am looking for. ?????? thx
https://www.ebay.com/p/2004-to-2009-...ray/1617819414
Old Mar 1, 2019 | 11:19 PM
F18Lumpy's Avatar
2013 ML350 Blutec / 2007 C280 4Matic
The prior owner of my son’s c280 4matic put weathertecs in, they handle the hump fine enough for me.
Old Mar 3, 2019 | 11:42 PM
jvakos's Avatar
thanks F18 - Appreciate the feedback very much. I ended up buying the oem Mercedes rubber floor mats for the w203 non-4matic And they fit fine on the passenger front side considering the transfer case bump.
Glad there are still many other c-class 4matic lovers out there )
