Transmission
Old Dec 30, 2013 | 10:00 PM
Jhguintu's Avatar
2002 Mercedes benz C240
Transmission
I have leak on my transmission and i want to change the fluid but i don't know the torque for the plug and the pan bolt. Does anyone know? Thanks in advance
Old Dec 30, 2013 | 11:04 PM
Carsy's Avatar
2007 W204 220CDI Classic Sedan
For 722.6 ATM .
Pan Bolt = 8 Nm.
Drain Plug = 20 Nm.
Cheers. JC.
Old Dec 31, 2013 | 07:10 AM
Stuka Bomber's Avatar
2007 c280
Dealer rec. new bolts as well as the factory ones are stretch bolts.
Old Dec 31, 2013 | 07:21 AM
krazzdav's Avatar
Veteran: Marine Corps
2017 GLA 250, 2011 C63 P31 (p30 w/ lsd) (in repair), 2005 C230 Sport Eurocharged, 2003 C320~sold
These aren't stretch bolts. I will pull the WIS instructions up to see what it says but I didn't change mine when I had to do it.
Stretch bolts that need replaced would be anything that would need an additional degree of turn after reaching the torque spec.
EDIT-- The WIKI had the instructions and it doesn't state to replace the bolts
https://mbworld.org/wiki/index.php/W203#722.6
Old Dec 31, 2013 | 07:55 AM
krazzdav's Avatar
Don't forget to get the measuring stick/dipstick, trans cap lock and TCU Connector. There are a lot of threads out there but this one had the TCU Connector PN# and good pics https://mbworld.org/forums/c-class-w...tf-4134-a.html
Old Dec 31, 2013 | 08:50 AM
2007 c280
^Correct sir, i just looked, my 722.6 instructions were from an early w210 chassis. My bad.
Old Dec 31, 2013 | 07:04 PM
Jhguintu's Avatar
Thank you all for your reply. This will help me a lot. Have a safe and Happy New Year to all.
