Tranmission mount/flex disc DIY.. Fill in the #'s...
Old Jan 19, 2014 | 09:32 PM
scottonfire's Avatar
2013 c250
Vibrations while driving, but not in idle or reverse, (goes away when I punch the gas and it switches to next gear [automatic]) so I hypothesize it's the trans mount, possibly flex disc(s).
So I raise car and put 4 jack stands propping her 18-24", put a jack with 10"x10" wood piece to support the trans pan to keep from denting. Fine.
Loosen or remove the brace with which? mm? sockets, then remove/replace trans mount and tighten to torque spec? for each mm? socket?
So, assuming I don't squoosh myself under my car, now I check the flex disc right up against the trans mount. If it's cracked/frayed, make a mark on the drive line so I don't f up the natural alignment leading to more effing vibration, then put car in neutral, spin disc and undo the 6 bolts, pry it out w/ a damn crowbar, replace flex disc and new bolts with loctite (blue shlt) on em, TORQUE SPEC #'s?
Then check other flex disc on front of car for cracks/frayed. Or not, drink beer, try to get friends to get car off of me. Why aren't these in the Wiki?
Old Jan 26, 2014 | 12:30 AM
2013 c250
BUMP.
Really? No one knows the torque specs for the transmission mount screws or flex disc?
Old Jan 27, 2014 | 01:41 PM
JamesC32's Avatar
2003 C32 AMG, 2015 RAM 1500 4x4, 2012 Merc GL450
torque specs
How about tigtten the holly &^%$^^$ out of them,,, thats what I did!!!
Old Jan 27, 2014 | 04:23 PM
2013 c250
Finally, a technical answer to my technical question.
Old Jan 28, 2014 | 06:05 AM
greenv's Avatar
2003 C230 Kompressor
Any person have instruction with picture to check this in my benz.
Old Jan 31, 2014 | 01:18 PM
VVF's Avatar
VVF
2005 C230K(sold), Mk7 Jetta
FYI,
Old Jan 31, 2014 | 01:46 PM
greenv's Avatar
Thanks for the information
