W203 INSTRUMENT CLUSTER UPGRADE
Old May 22, 2021 | 08:39 PM
sunman2's Avatar
2014 E250
I’ve done this upgrade before
I’ve retrofitted possibly all features on my previous w203. One was the 209 cluster. Search under sunman.
Old Jul 24, 2021 | 06:14 PM
darmanchester's Avatar
w203
Instrument cluster upgrade
Originally Posted by Mackhack
I can help with this if anyone needs help, PM or email me.
please am using a w203 01 and I want to install a 07 instrument cluster
Old Jul 24, 2021 | 06:19 PM
Mackhack's Avatar
Send me a PM
Old Aug 11, 2021 | 01:14 PM
RicoC240's Avatar
C240
I am new to mbworld and I also have an 01 w203 C240 that I upgraded the instrument cluster to an 07 C230 direct plug and play except one problem. The fuel gauge reads erratic now never knowing how much fuel you actually have. And trying to keep track of miles before your next fill up before you run out of gas/diesel sucks.
So if anyone can help me fix this problem I heard it's a matter of flip flopping some wires to the new correct spots but i don't know where exactly to start.
Old Aug 11, 2021 | 01:21 PM
Mackhack's Avatar
Feel free to message me for help with your cluster.
Old Aug 11, 2021 | 01:57 PM
RicoC240's Avatar
C240
Mackhack I tried to DM you but it won't allow me. Here's my email chipgotay@gmail.com
Old Aug 11, 2021 | 02:17 PM
  #32
Mackhack's Avatar
I’ll email you in a bit. I’d take the email address out so bots won’t find it and add it to spam lists.
Old Aug 18, 2021 | 04:46 PM
  #33
w203
please email me to I want to upgrade my C320 01 instrument cluster to a 07 thanks
okorod01@gmail.com
Old Aug 29, 2021 | 03:13 PM
  #34
rmanet's Avatar
C230 Kompressor
Tried to DM you - email is slocko@gmail.com. Just want to program replacement cluster to old cluster miles - get rid of the ----------
Have all sorts of tools, W203 (2002) options limited - if you could, need some help - THKS
Old Aug 31, 2021 | 07:09 AM
  #35
BenzNinja's Avatar
Former Vendor
I can do that
Old Sep 2, 2021 | 01:05 AM
  #36
mariochan's Avatar
Ml 350 bluetec
Mackhack I want your help too. No way to message you. Pls message me or email me mariochan333@gmail.com. thnx
Old Sep 2, 2021 | 06:16 AM
  #37
BenzNinja's Avatar
Former Vendor
Originally Posted by mariochan
Mackhack I want your help too. No way to message you. Pls message me or email me thnx
don't you see he is banned
if you expose your email open on boards, don't be suprised it goes on spambot's lists and you will be flooded with spam emails within days
Old Sep 2, 2021 | 01:09 PM
  #38
mariochan's Avatar
Ml 350 bluetec
I should wear that newbie badge with pride 😂
However our emails are all over the internet and full of spam to begin with. Thanks anyway!
Old Sep 2, 2021 | 02:10 PM
  #39
BenzNinja's Avatar
Former Vendor
my pleasure but remember, forums are a great source for spam spiders
you can edit your post to remove it
Old Nov 12, 2021 | 12:53 PM
  #40
Ray Don's Avatar
01 c320 [w203]
Mackhack I want your help too. No way to message you. Pls message me or email me gunn
email me please gunnadadon@gmail.com
Old Dec 1, 2021 | 02:46 PM
  #41
W203newbie208's Avatar
I own a 2002 c240
My worked jst fine
Originally Posted by LouCamilleri
i have read so many different opinions on upgrading an instrumet cluster on a 2002 w203 with one out of a 2005 w203. i am interesed in hearing more about this idea. I have bought an instrument cluster from a 2005 w203 and installed it in my 2002 model and all the lights on the cluster lit up except for the section between the two gauges which show mileage etc, etc.
i am aware that the milages is stored in a seperate computer on this model and im not sure if it is that because the two milages did nt match was the reason the center section did not display.
i was told that the reason was that the cluster was nt talking to the computer and that mercedes could marry up the two,the tacho was nt working neither were the gauges just all the warning lights lit up eg. hi beam, srs, esp etc etc look forward to any input regards lou
I swapped one out of a 2005 c240 into my 02 amd it worked just fine. Gauges fuel. Miles ect. Guess I got lucky
Old Dec 1, 2021 | 09:47 PM
  #42
Benzrider17's Avatar
C43 c55 C63
Think it has to do with the setting your car came with ,I also swapped out mine and 2 other of my friends we all purchased the same part number but one we couldn’t change the clock setting but all other functions work as they should even steering wheel buttons for the radio control
Old Feb 19, 2022 | 03:23 PM
  #43
marcin zzzz's Avatar
cls
Clouster cls mercedes
hi I heve cls 2006 with foulty closter. Would you be able help?
Old Jun 27, 2022 | 05:18 PM
  #44
Luarm204's Avatar
2003 mercedes e320
need help with used instrument cluster. please email at lu_armenta@yahoo.com thanks
Old Jan 13, 2023 | 10:23 PM
  #45
Billy Barber Jr's Avatar
2006 Mercedes E350
Mackhack
I need help on marring a 2005 cluster to my 2003 c32 amg. can i get your email address
Old Feb 4, 2023 | 05:26 AM
  #46
Redo's Avatar
W203 C270 (2002)
Can you send me a private message
[QUOTE=Mackhack;8393662]N'hésitez pas à m'envoyer un message pour obtenir de l'aide avec votre cluster.[/QUOTE
]Hello, I would like to message you to ask for help during the installation of my cluster
Old Apr 14, 2023 | 12:40 PM
  #47
Darkboy19's Avatar
C class w203 c200 2001
mm
Old Sep 5, 2023 | 06:33 AM
  #48
Mbcyprus's Avatar
W203 220cdi and w212 220cdi
Ö.M.
please send me pm
Old Dec 11, 2024 | 03:33 PM
  #49
smiler66's Avatar
Cl203 320
I wanted to change my cluster panel for a later model too. I have a 2004 c320 and was looking at a CLC cluster with chequer boarding pattern and white around the dials. I bought one second hand and as I was going to replace it I needed to get the mileage corrected but instead I took the one from the car and dismantled the front panel and trim off the cluster, I was then able to gently remove the black face plate from both and swap them over!!! ( They are just stuck on anyway ) This solved the problem of the mileage and as I was using the old cluster with a new face on it it worked perfectly. It was also a very cheap result !!!!!!!!!
Old May 3, 2025 | 10:14 AM
  #50
sweets808's Avatar
I cant seem to find how to contact you. I need some help with my w203
Currently Active Users Viewing This Thread: 5 (0 members and 5 guests)
