M272 Thermostat Bolt
You can email that dealership and ask for part# etc.
A 002 990 72 22.
I am pretty sure, that bolt is same for your 06 C280 (M272).
pcy - that was exactly it.
I was able to get the bolt needed and finish up the thermostat job. I feel like I did everything according to procedure but I've run into another issue. After refilling the antifreeze and running the heat on full blast, I'm still not getting any hot air. What did I do wrong and how can I fix this?
My steps were:
1) Fill coolant
2) Let car run with heat on for a few minutes
3) Refilled coolant
4) Squeezed upper radiator hose to burp
5) Run the car, again with heat on full blast
Still no hot air. Am I not giving it enough time to recirculate? It's still pretty cold here in MN. Thanks again.
