Sunroof Track Servicing.
Old Feb 3, 2014 | 04:26 PM
mercedes4ever's Avatar
2004.7 C180 Kompressor, BMW X5, Chevrolet Camaro LT, Mercedes S, Cesna 152.
Question Sunroof Track Servicing.
There is probably a thread or 3 on this somewhere? Is it OK to clean your sunroof (pano) the following way;
1. Clean debris etc out of tracks, using a microfiber cloth moistened with alcohol.
2. Lubricate tracks with Silicon spray.
Is there any other method / requirements?
Old Feb 3, 2014 | 05:59 PM
Moviela's Avatar
Clean with a cloth only. You should not use silicone spray anywhere. Please see this thread post #35 for proper cleaning and lubrication.
https://mbworld.org/forums/c-class-w...-thread-2.html
The special lubricant is DuPont Krytox.
Old Feb 6, 2014 | 09:30 PM
OK. Dupont Krytox is a Teflon based grease. I will redo with a Teflon. Silicon sprays do not hold dust & dirt like petroleum based lubes, and are excellent at lubricating.
Old Feb 12, 2014 | 10:29 PM
ATXJosh's Avatar
2003 C320
Occasionally, my sunroof will act as though something is stuck in the track and "re-open". When this happens, i clean the tracks with a microfiber and some non-amonia based cleaner (My wife is fond of Method glass cleaner, so that's what i use). I really get in there, and usually come out with quite a bit of grit, dirt and old lubricant. When I'm satisfied that I've cleaned it as best i can, give a light coating of some automotive grease (I use a brand made by Mobil 1 that comes in a long tube and is designed for a caulk gun). Go light on this stuff - i typically put some on the corner of my rag and lightly work it in. You don't want gobs of this stuff in any part of the track, it'll collect dirt can jam your action up. Light coating. Sunroof should work fine with no issues if you do this periodically. Whole process takes me about 20 minutes.
