Measuring rotor thickness WITHOUT taking off wheel?
Thanks!
The tool needed to read the thickness requires precision to get a meaningful reading. It is a deep throat micrometer. Here are eight examples of those typically used in the automotive trade.
http://www.starrett.com/metrology/me...ortBy=none/asc
Using a standard micrometer or calipers is worthless. It is a serious safety problem to run rotors that are too thin. If you cannot measure the thickness properly, just get new rotors. Factory rotors are good for two sets of pads as a general rule.
Problem is, even if I fight off my cheapness and get front rotors without measuring, how do I know the back ones don't need replacing too? I don't, which means I'd need to replace the pads and rotors in the back and that my cheapness cannot stand.
I've found some $50-$80 digital micrometers that measure b/w .300 to 1.300 inches. What do you think of the one below? And could I use this to measure the back brake pad as well since there's no sensor to tell me whether it even needs replacing?
Thx,
http://www.autozone.com/autozone/acc...er=186497_0_0_
Seriously with the amount of money you're saving DIY, if you're doing brakes every two years I would suggest replace the rotors along with it and save the hassle of potential problems during your use of the second set of pads.
Rock Auto sells some good things, but $13 rotors are something you should only consider for a car you are selling. If you keep the car you will have the aroma of rice every time you step on the brake.
You don't want the rotors to wear out before the pads.
Those pads last nearly forever.
Still waiting for mine to wear out, 130K miles on them....
the car will collapse around them, and they still be there.
