changed the chain today....(rant)
I wish I new what variable make a difference...
It was a pain in the a$$, but now you've done it and you know what you have. Peace of mind is worth something!
Congratulations on the replacement, BTW!
Well it was hard. I had to enlist an assistant. Feeding that chain around is a b!@ch...couple of times the cams sprang forward or back and the timing went off and the pistons kissed the valves.....better with the crank being turned by hand than at 5500rpm though...
I havent run it yet though...doing a coolant flush and oil change too.....
I've always used the start up rattle as a guide to changing but we have a few that let go without a rattle or the owner was deaf.
It is hard to know what to recommend. I'm sticking to my first signs of rattle with friends but I do really think it should be a standard service item for replacement at about 120K miles.
Anyway ~ it's behind you now & you can sleep at night.
The "variable" thats makes all the difference, is oil / filter changes @ 6 monthly intervals, using ONLY MB oil / fleece filter. Stated to me "off the record" his own opinion, by Chief Tech MB Australia.
The 130K Km car we are fighting with Benz about in SA was on Mobilodrive plan & only serviced by Benz with the correct products at the right time. 15,000Km or 1 year.
The chain let go while the car was in for service at the dealer & being test driven.
This engine needs a duplex chain.
I'm remembering that someone did a part search on a TC for the Evo and it appears the chain was an upgrade compared to the older 271s.
Overall the engine sounds....normal!
Tomorrow I will try to remember and make a cold start video to compare with the old one.
Here is what it used to sound like: pay attention to the 35 sec mark
https://www.youtube.com/watch?v=qWdq...ature=youtu.be
Need to check for TC death rattle, when car engine is cold, once they warm up the rattle can quickly go away.
+1^. worn chains wear sprockets & worn sprockets wear new chains. Generally the sprockets survive in good condition on the M271 if you change the chain at the first sign of startup rattle. You have to change the use-once tensioner element when fitting a new chain. The tensioner/chain guides are fortunately robust on these engines.
I tried getting the chain replaced at local trusted mechanics, but no one would touch it. Dealers said it was not necessary and were not willing to help. This played a major role in my decision to move on, something I regret doing to this day. I wish I had pushed harder or looked at a broader area to find someone to change the chain and kept the car.
