2003 c230 wiper blades not working
The wiper blades don't work, so here's what I did so far.
I connected the wiper motor plug directly to the battery (red to positive and brown to negative) and the motor worked fine and linkages were moving back and forth fine.
the wiper fluid come out fine when I push on the switch.
the wiper blades switch does not work in any position.
I replaced the 2 yellow relays in the fuse box under the hood with new ones.
I don't know what else to do. does the switch need to be replaced or is there something else. Thank you for your help.
