Are you smarter than a MB certified technician?
Old Feb 16, 2014 | 04:25 PM
leonelalbarran's Avatar
2006 C230 Sport
I have a pop/thump noise coming from the rear of my C230 Sport w/ auto trans when I am at a complete stop with the brakes applied and in drive. For example at a stop light or a drive thru. It starts with a soft noise like a click then 2-3 seconds later a very rapid series of thumps/pops happens then it goes away until I come to a complete stop again with the car in drive and the brakes are applied. MB technicians can't figure it out after $1200 in diagnosing fees. Hence the title of my post. I am new to the MB world so any help would be very MUCH appreciated!
Old Feb 16, 2014 | 05:00 PM
tee's Avatar
tee
E55,GL 450,Subaru STI,Chevy crewcab
Canister shut off valve or purge valve up against the body.
Old Feb 16, 2014 | 05:36 PM
Carsy's Avatar
2007 W204 220CDI Classic Sedan
I get a loud "grumble" type sound sometimes when light breaking & when almost stopped . It is pretty normal & caused by pad vibration . I think a pad grease may fix it but I have never bothered.
Try doing it with someone else driving with you standing beside or running beside the car. You may be able to pinpoint the location. I have to do this sometimes to find which disc stone guard has a stone underneath it !!
Old Feb 16, 2014 | 05:54 PM
2006 C230 Sport
Thank you guys for the input. I really appreciate it. Tee, have you had the same issue and did you fix it by working on the parts you mentioned? Carsy, thank you for replying but my issue occurs when I am at a complete stop with the brakes applied to keep the car at a stand still
Old Feb 16, 2014 | 05:55 PM
2006 C230 Sport
Did you have same issue and is that how you fixed it? Could you tell me a little more?
Old Feb 16, 2014 | 06:50 PM
tee's Avatar
tee
Look at the purge valve it is located by the left front head light start the car and when you hear/ feel the thumping see if it matches the purge valve. Very common that people complain about this you can insulate it from the body better with felt tape and that seems to help. If it is the canister shut off they make more of a popping type sound from the r/r of car.
Old Feb 16, 2014 | 07:48 PM
Glyn M Ruck's Avatar
Super Moderator
EECS Purge valve.
Also twin fuel level sensors under the back seat can make strange knocking noises.
Old Feb 16, 2014 | 08:37 PM
tee's Avatar
tee
Originally Posted by Glyn M Ruck
EECS Purge valve.
Never seen the fuel sensors make noises but lots of purge valve noises.
Old Feb 16, 2014 | 09:01 PM
Super Moderator
You will find a thread by LILBENZ (Matt) IIRC where we discuss noisy fuel level sensors.
Old Feb 16, 2014 | 11:57 PM
tee's Avatar
tee
I'm not doubting you just saying I have never seen fuel senders make a thumping noise
Old Feb 17, 2014 | 09:03 AM
BF_JC230's Avatar
2005 w203 C230
[QUOTE=leonelalbarran;5944536] MB technicians can't figure it out after $1200 in diagnosing fees. QUOTE]
Did you pay them $1,200 for nothing?...Did they take $1,200 for no work rendered/issue resolved?
Old Feb 17, 2014 | 10:39 AM
2006 C230 Sport
They connected the OBDII machine. Took a look at the car. Lifted it up and looked underneath. I mean they have tried but after 3 attempts of looking with no results is just hard to believe lol.
Old Feb 17, 2014 | 10:41 AM
2006 C230 Sport
Thank you all for the replies. Quick question for you tee, would this sort of thing not throw a code? That is one thing I forgot to mention in my original post. The computer is not throwing any codes....
Old Feb 17, 2014 | 12:43 PM
tee's Avatar
tee
It will not throw a code because the valve is working. You could unplug the purge valve and drive it to see if the noise is gone but doing this will store a code.
Old Feb 19, 2014 | 07:10 PM
Holmes5518's Avatar
2016 C450
Sounds to me like you are describing the tapping of the charcoal canister. They are loud on 203 sedans particularly and Mercedes has released a small aluminum machined sound dampener that is installed inside the rubber hose to the charcoal canister. It dampens the light clicking/tapping sound from the RR of the vehicle. Give it a shot, the part is really cheap.
Old Feb 19, 2014 | 07:16 PM
Holmes5518's Avatar
2016 C450
Part Name/Part Number
1 Restrictor A203 476 03 32
1 Clamp A005 997 19 90
Old Feb 19, 2014 | 07:19 PM
Holmes5518's Avatar
2016 C450
This is where to add the dampener to
Attached Thumbnails Are you smarter than a MB certified technician?-charcoal.jpg
Old Feb 20, 2014 | 08:31 AM
Super Moderator
That is extremely interesting. All SA built W203's had those, Well certainly my old 2003 C240 had one. SA cars also had a rubber pad under the bracket that bolts the purge valve to the shock tower.
So it's the restrictor that damps the purge line. Makes a lot of sense.
In that case unplugging the purge valve would confirm it's the purge circuit that's transmitting the noise.
I would definitely fit one.
Old Feb 20, 2014 | 09:39 AM
Super Moderator
Old Feb 20, 2014 | 06:39 PM
Holmes5518's Avatar
2016 C450
It's not really a well known fix, even at the dealership level. The amount of affected cars seems very small so the info isn't well known among techs or service writers. His symptom sounds exactly like this issue.
Old Feb 20, 2014 | 09:00 PM
Super Moderator
Indeed they do! Thanks for the info!
BTW ~ (listed in the EPC as 35 A 203 476 03 32 VALVE REGENERATION LINE 001) no picture.
Old Feb 20, 2014 | 10:18 PM
Holmes5518's Avatar
2016 C450
this is what it looks like
Attached Thumbnails Are you smarter than a MB certified technician?-charcoal2.jpg
Old Feb 24, 2014 | 06:05 PM
C230 Sport Coup's Avatar
C230 Sport Coup + 2006 W164 ML350 + 99 Ford Escort RIP
To answer the original question, yes, Glyn is smarter.
