Front end noise
Old Feb 23, 2014 | 12:31 AM
Bewy's Avatar
2000 model C240
Front end noise
Hi Folks, I recently bought a 2000 model C240 [ build date December 2000 ]. It has done 143000 km. I notice that after driving it for about 20 mins, a noise develops in the front suspension. Hard to describe the noise, a 'graunching' sound like rubber against rubber. I can jounce both the left front or the right front & it makes the noise. I am not sure if the noise is on one side & this is 'referred' noise or if in fact there is a problem with the both sides. It takes very little car movement to get the noise, does not have to be a large bump to get the noise. Any common problems with these? Any ideas?
Thanks.
Old Feb 23, 2014 | 02:02 AM
Holmes5518's Avatar
2016 C450
Thanks.
Record it and upload the video to youtube
Old Feb 23, 2014 | 09:01 AM
Glyn M Ruck's Avatar
Super Moderator
Common sources are the Caster arm bushes or sway bar links & bushes.
Check for cracks & silicone fluid leakage from the Caster arm bushes.
Old Feb 27, 2014 | 03:47 PM
Bewy's Avatar
2000 model C240
Update. I replaced the front stabiliser bar pivot bushes with polyurethane bushes & so far no more front end noise. Will be doing the same with rear bushes.
