Unable to fill with fuel
and I live in the UK.
about 2 months ago whilst in France I pulled in to fill with fuel and even though the nozzle went in OK fuel would just dribble in and the gun would cut out as though full. I pulled into another station and fuelled with no problems.
This week I did the same thing and the fuel would not go in, I managed to get 12 ltrs in after about 15 minutes. This has now become a common occurrence as I tried again last night and suffered the same humility.
Please, please help
Thanks in advance
This overflows gasoline into the charcoal canister, which is only designed to trap fuel vapors. Even if you didn't cause it with topping off, they sometimes just fail and do not vent properly when you are filling causing the nozzle to click. The gas tank needs to vent air when filling up with gas, and if it can't, you won't be able to fill properly.
Good luck.
Thank you kindly, this ticks all the boxes, I shall order one today.
I travel a lot in Europe and have a tendency when locating fuel at a cheaper price to try and get as much in the tank. For once I should have taken notice of the owners manual.
Once again many thanks.
I have check the carbon filter and that was fine.what confuses me is the valve assembley that is attached to the top of the filler pipe under the rear wing.
Could someone explain it's exsistence and could this be the cause of my problems.
any other explanation to the no fuel problem would be gratefull appreciated.
at present having to stick a rod down to hold the anti siphon flap open and hold the nozzle about 10mm away from filler so air can escape. now takes 20 minutes to fill.
It seems that you think you are the oracle and everything that you utter is correct, in the reply that you gave me in the other thread I tried and as you can see it did not make any difference.
You have then either failed to read the rest of my thread as you have not answered any of the other questions.
I notice that you have posted 114 times, I hope that they gave valuable information because your answer to me "I answered that in another thread" is completely pathetic. I hope a moderator is looking at this as I think you bring down the credit ability of the forum and if that is your best answer to a real problem then don't waste your energy as it was worthless
ZAYED,,
I am a degree engineer with many years experience and have a staff of 30 engineers, when we have problems we throw it in the pot and discuss. We do not throw out " I already answered that" which in itself indicates that the author believes he has solved the problem.
I see you also have not looked at the other thread before jumping. Good principle " have all your soldiers in a row"
And I do apologize for saying that you did not appreciate his answer, that was just my interpretation from what I read.
OP ~ If no one has intentionally stuffed something down your filler pipe you have a tank breather problem or EECS (Evapourative Emission Control System) problem. You are going to have to do a systematic check of the items illustrated.
This is for 112 engine but all EECS systems are basically the same. Schematic is valid.
You can find additional information on the subject in the W203 Wiki. If you need the SLK tank arrangement I can post.
Good luck!
