Normal engine temperaturе?
Old May 13, 2014 | 08:00 AM
Mike10's Avatar
w203 C240 4-MATIC
Question Normal engine temperaturе?
Hello.
What is the normal temperature of these engines in the C-Class C240 / C320 (m112 - petrol)?
My hold 95-98 degrees. (photo)
Old May 13, 2014 | 08:12 AM
blzdout's Avatar
C240 4MATIC
I have the same car, I will check later on today for you & post my stats. That kinda looks normal if I remember correctly.
Old May 13, 2014 | 08:27 AM
Mike10's Avatar
w203 C240 4-MATIC
Thank you. My temperature is around 95-98 degrees urban driving. I wonder if this is not very.....
Old May 13, 2014 | 08:29 AM
jkowtko's Avatar
2005 c230SS
I have the M271, just bought an Ultra-Gauge and have been watching the engine temp ... usually around 190F +- 10F, but I've seen it go up to 210F after startup.
I was a bit alarmed at first but now that I see it regularly I don't worry.
My thermostat and temp sensor were replaced around 90k by the MB dealership.
Old May 13, 2014 | 01:07 PM
blzdout's Avatar
C240 4MATIC
From urban driving in my city @ around 70 degrees temp outside, I hit the 90F-95F range on my engine's temp. It is completely normal. You have to remember, the engine generates a lot of heat since it's responsible for pushing a 2-3ton car lol.
Old May 13, 2014 | 01:27 PM
Alswag's Avatar
2003 CL203 C320, 2002 W208 CLK320 cabriolet, 2012 A207 E350 cabriolet, 2011 X204 GLK350 4matic
Although our thermostats are rated for 87 degrees (I believe), it's completely normal to see the car sit just below 100 degrees in traffic or urban driving conditions. If it goes past 100 degrees, then you probably have a cooling issue. The coolant/water in the cooling system will only start to boil well beyond 115 degrees, but you never want it to even get close to that point.
Old May 13, 2014 | 01:40 PM
blzdout's Avatar
C240 4MATIC
Plus, you'd get "COOLANT VISIT WORKSHOP!" message on your cluster if your car is running too hot if I'm not mistaken.
Old May 13, 2014 | 10:20 PM
c200_lahore's Avatar
c200
Hi! I have C200 Kompressor 2005 and since it has analog meters, I can only share an estimated reading: around 90 degrees celcius which is very normal.
