ESP Problem
I drive a 2005 C230 Kompressor Sport Sedan. A few days while I was driving back from work, this fault message came up on the screen; ''ESP Malfunction, visit Workshop''. Sometimes it changes to ''ESP Unavailable, see Operator's Manual''.
Please can anyone advice me on what to do to solve this?
Thanks.
Have you done any work on the car in the recent past?
Most of the time that ESP indicator will come up and you just need to turn your steering wheel from lock to lock and it clears.
If it does not clear you may need to replace the steering angle sensor. That would require you to remove the steering wheel.
Thanks,
I've tried the steering wheel lock-to-lock idea but the message(s) is still there.
Anyways, I was able to take the car to my mechanic today, he used STAR and diagnosed the fault as Steering Column Module (SCM) failure, just as you had predicted. He says it needs to be replaced.
What do you advice? Can it be repaired or must I buy a new one?
Awaiting yours.
Thanks...
Awaiting yours.
Thanks...
There are several good DIY steering column how too's out there search for one and the job is not difficult. even for a novice. Just simple clips and bolt removal.
Good luck
Good luck
https://www.genuinemercedesparts.com...iagram=5776320
kilmer81: My suggestion would be to look in the wreck yard too. These sensors do not have PCB's where dry solder could be an intermittent problem. So if the old sensor works, it should be ok and good otherwise return them. This would be very cost effective. I am waiting for the availability of this sensor in the junk yard where the price could be one third. I am also told that once you put in the sensor, you need to get it to someone who has this STAR or other diagnostic to calibrate. However, that should not be expensive at all.
