throttle body problems...
Old May 26, 2014 | 11:23 PM
pogijeffrey's Avatar
05 c230 kompressor
hi guys. its been a while since i posted but i need your help. today my car finally gave out. my car just started idling up and down with no pedal response. i had a friend check the code and they said its the throttle body actuator. but thats all he told me. is there anything else i need to check other than that...? and how much would it cost me to repair this...?
Old May 27, 2014 | 10:11 AM
Javvy's Avatar
13 Jeep JKU Sahara w/4" lift Kit & the works,2015 Toyota Sienna XLE,2013 Hyundai Sonata Hybrid
Post the codes please....
Javvy
Old May 27, 2014 | 12:35 PM
05 c230 kompressor
Sorry I don't have the codes... But that's what they read of the computer when checking the code.... Throttle body actuator ....
In my car, the dash says "esp malfunction"
Old May 27, 2014 | 06:18 PM
05 c230 kompressor
Here are the codes
P2001
P2009
P2032
Old May 27, 2014 | 09:06 PM
Glyn M Ruck's Avatar
Super Moderator
There is something wrong with those codes.
Throttle body & TPS codes are 2100 to 2140.
The way the car is behaving tells me it is usually the TB actuator going into oscillation which usually means a new TB. Try cleaning up the TB tracks etc.
Old May 28, 2014 | 12:49 PM
05 c230 kompressor
Here's a video from inside
Old May 28, 2014 | 12:50 PM
05 c230 kompressor
Glynn, what's tps?
Old May 28, 2014 | 03:15 PM
hanknum's Avatar
'02 C320 Wagon, '78 308 GTS, '06 Highlander Hybrid
Glynn, what's tps?
TPS = Throttle Position Sensor
I've got a spare throttle body if you need, but not sure if it's the same...it's off of my M112 engine.
Old May 28, 2014 | 03:24 PM
cm60k's Avatar
Do you clean or resealing a T/B...??
ZAYED,
Old May 28, 2014 | 03:48 PM
05 c230 kompressor
I haven't cleaned anything yet... I'm getting it towed to my friends shop... He's thinking that the car just needs to be relearned... Adaption is what he called it...
Could it be that my pedal failed instead?
Old May 28, 2014 | 03:57 PM
cm60k's Avatar
Can you see the T/B closely, maybe the cable that attached to the T/B stocked with something,
its happened with my friend before...!!
ZAYED,,
Old May 28, 2014 | 04:20 PM
cm60k's Avatar
You can also do a sneaky reset:
1) Turn the ignition key to the on (not start) position.
2) Press the gas pedal to the floor and hold for ten seconds.
3) Turn the key to the "off" position (don't remove the key), then release the gas pedal.
4) Wait at least two minutes for ECU to reset.
ZAYED,,
Old May 28, 2014 | 08:16 PM
05 c230 kompressor
It was the throttle body actuator that gave out... The flap would not open smooth .. It kept locking... We took apart the plastic backing and saw that the teeth on the gears wear worn out with teeth missing...
Old May 28, 2014 | 08:32 PM
Super Moderator
That figures I'm afraid. At least it's diagnosed.
Old May 28, 2014 | 08:42 PM
05 c230 kompressor
Yup... It'l be ready tomorrow... Cost me an arm and a leg though.. And wasn't planning on spending so much for a car that has 190,000 miles. But it's ok... All major components have been replaced already. It should last a few more years after this. And I'll take pictures of the faulty throttle body when I get it back tomorrow...
My mechanic says he never seen anything like this before...
Old Oct 29, 2020 | 06:29 AM
Vani Geziyorum's Avatar
driver
help
help please i have the same problem in my car
Old Dec 1, 2020 | 09:57 PM
Spitfire69's Avatar
'04 Nissan 350Z 6sp manual, '04 W209 CLK320 5sp Auto, '05 W169 A170 6sp CVT, '69 Triumph SpitfireMK3
Throttle body failing cause
I have been working on my uncles' c180 kompressor for WAY too long now, but finally came to the point where after reworking the entire intake system and vacuum system & replacing the CAT and A/F Lambda sensor there is only 1 code remaing P2001 Throttle body valve PWM (Pulse width modulation).
This is the 2nd used throttle that has been fitted and previously it was the potentiometer values. (3rd time lucky 🤞🏻 )
I figure with the high force of the return spring and the supercharger pressure on the throttle body, not to mention that it has to work/adjust every time with the movement of your foot, the poor part won't last (I think it's too small as well tbh, but then again it wasn't intended for performance 🤔 )
You most certainly need a diagnostic machine to read & clear fault codes in your endeavour...
Good luck 🤞🏻
Old Oct 2, 2023 | 09:56 PM
Killa' Benz's Avatar
E230 W210
Did you buy a new or used one? Is it plug and play?
