Need A/C help!
Old Jun 21, 2014 | 05:38 PM
Michael1975's Avatar
2002 Mercedes C230
Need A/C help!
I have a 2002 C230. Last week, my car started making noises kinda like someone threw a couple wrenches in a dryer. I assumed the tensioner was going, but it didn't sound quite like any tensioner I have heard before. Fast forward 3 or 4 days and all the sudden the a/c stopped working and the sound got worse. By the way, it is the loudest when I start the car. It isn't as loud after a couple minutes and strangely isn't any louder at higher rpms.
A little more info, the system is pressurized, so no leaks. Also, there is no difference in sound or rpms between turning the a/c on and off, so the compressor isn't trying to turn on.
What I need to know is, does the a/c compressor have a clutch on this car or do I need to replace the compressor?
Any help is MUCHLY appreciated!
Old Jun 21, 2014 | 08:33 PM
Glyn M Ruck's Avatar
Super Moderator
No clutch on the HVAC compressor. It is a swash plate compressor. Sounds as though the compressor might be damaged. Remove Poly V belt & check all accessories.
The Refrigerant must be at full pressure or the A/C wont turn on.
Old Jun 21, 2014 | 09:43 PM
2002 Mercedes C230
Thanks for the reply!
That's what I thought. Unfortunately, its our only car so I will need the parts to fix when I take it apart. Maybe I need to rent my wife a car while I fix it, ughhh..
Old Jun 22, 2014 | 03:09 PM
VVF's Avatar
VVF
2005 C230K(sold), Mk7 Jetta
Do check the alternator overrun pulley. If it's seized that might be the source of the noise and the reason your AC compressor pulley failed.
