cam shaft sensor torx bolt torque specification?
Hello,
Replacing the camshaft sensor on a 2005 c230. It has 3 torx bolts which attaches to the front of the head. Does anyone know the torque specifications for these three retaining bolts? I've read several DIY but none specify the torque specification for these bolts.
Thanks in advance!
Thanks in advance!
Do you know the torque spec for reattaching it?
https://mbworld.org/wiki/index.php/F...shaft_M271.pdf
Says 8 Nm.
Generally it is not a good idea to overtorque these since the engine block is made of aluminum.
Says 8 Nm.
96 and 08 911 turbos
Says 8 Nm.
Says 8 Nm.
