MacNeil cargo mat for the Coupe...
2002 C230K
I went ahead and purchased the cargo mat from MacNeil (http://www.mats.com) for the Coupe. As you can see, the mat does not come with the cutouts for the cargo loops, but it's not going to be a big deal to cut them out myself. The only downside to this is, holes cut in the mat will eliminate the "spill catching" capabilities. Suffice it to say, I'll just have to make sure I don't carry anything that will potentially spill. Overall it's going to save the carpet either way though.
The material they use is not the same soft rubber they use in their floor mats, but it's a flexible semi-soft plastic material. As you can see, they did a very good job in matching the form of the trunk area, and I have no complaints about how it fits. There is an area of the trunk by the sub woofer where the floor is a little lower. This causes the mat to bunch up a little because it ends up below the lip of the sub woofer compartment. Trust me though, it's not a big deal at all.
2002 C320 c2/c3/c4 & command
Bos, it looks very neat and nice. I did check out the site you gave us and the C320 cargo matt cost$89.9 with shipping $9.
Now, I have a question about the D ring I'm using for the net sill. How hard is it to cut the slit to fit the D ring? And Did you do it in yours? I didn't see it in your pitctures. Thanks !!
Bos, the fit looks great! Almost too good, actually, because if you really want to cut slits for those D rings, you'll have to be very precise on where the slits go, otherwise you could end up with rings slits that don't match the fit of the mat in place.
My suggestion would be to point the floor rings vertically and tape in place with masking tape. Then, coat the top of the rings with vaseline (or something) that will stick to the mat, once you test fit it in place over the rings at attention. Then remove the mat, turn over, and see where the vaseline has made its mark on the underside of the mat. Replace the vaseline marks with a more permanent mark in ink, then start cutting the slit, a little at a time, from middle to outside edge.
If you decided not to cut the slits, the mat would look great, anyway. If needed you could put an old sock/rag under the carpet on the right side to bring the carpet/mat level, too.
Just sticking my nose in with some random thoughts.
2002 C230K
My plan on this is to pull out both the mat and the carpet and lay the carpet on the mat and use it as a template. The other thought I had would be to include tear proof holes at the end of the slits. In other words, cut the slits like this O--------O with a hole at each end. This should also work out well as a place for the D ring to sit, if you get the slit lined up correctly to begin with.
This would also help with the fact that you just cut into a mat that supposed to help prevent spills. Since the slits could be cut in such a way as to line up right around the d-ring and lay flat to help keep out any spills. Albeit, not totally waterproof, but better than a large slit.
2002 C230K
Naw, just a shadetree engineer, at best. I like your idea of o----o configuration for the slits.
However, unless you can make these cuts precisely enought, and unless the D-Rings fold flat once through the mat, I wouldn't do it at all. Think about it. The cargo nets is to hold objects between the net and the floor that would otherwise slide around on the carpeting. But, IMO, the grippy mat should hold objects in place without a need for the net (or D-Rings).
My suggestion would be to drive it for a couple weeks with some objects back there to see if the mats do the job. If the objects don't move around, I'd then drop-kick the idea of cutting the mat at all.
2002 C230K
Having said that, I don't think I'll be able to live with out the net in place. I also agree about being very precise with the slits. As I said, I'm quite **** when it comes to these things, so I should be able to kill a couple of hours on Sunday.
My thoughts at the moment are to mark where the edges of the D-rings are on the mat. Then I'll use a drill with a bit that's the same size as the diameter of the D-ring post to make the holes. Not that a drill is necessary, just the easiest way I can think of to make a nice round hole. Next, I'll just connect the dots with a utility knife so it creates a very thin slit. We'll see how it goes. When I'm done, I'll be glad to post more pics if anyone is interested.
here's a link that shows them
https://mbworld.org/forums/showthrea...ighlight=cargo
what about not cutting the slits? when you need the nets, lift the mat from the corners and attach them. the mat would sort of envelope whatever you want to hold. not having the mat, i'm not sure if that would work but i'd try that.
btw, the fit looks so good, you've just convinced me to get one for myself
if you do drill, i'd recommend using a piece of wood underneath to keep the mat flat. but i don't know if you're going to get a clean hole.
'05 c240 4matic wagon
Then use a metal rule to guide the blade.
Hah, this is fun. I love 'hands-on'...
