Code P0456
Old Aug 5, 2014 | 04:37 PM
w203driver's Avatar
2005 C230 kompressor
Question Code P0456
Hi I am new to this but I just purchased a lovely 2005 c230 k sedan and the check engine light is on but I have a computer that does diagnostics and this code came on is it something serious? and also for some reason when I park it on the hill the gas light comes on after I just put gas in it is this a problem? ( there are no gas leaks under the car from what I can see), thanks also the car has only 107,000 miles
Old Aug 5, 2014 | 04:50 PM
VVF's Avatar
VVF
2005 C230K(sold), Mk7 Jetta
This should get you started: https://www.google.com/webhp?sourcei...w203%20mbworld
Welcome to the forum!
Old Aug 6, 2014 | 09:40 PM
w203driver's Avatar
Thanks but do you know if it would effect my car passing inspection right now i am driving it on my dads dealer tag
Old Aug 7, 2014 | 06:13 PM
AutohausAZ-Mike's Avatar
Former Vendor of MBWorld
If your light is on during the inspection, you won't be able to pass.
The most common problem for that code would be the gas cap. If that's not the issue you will probably have to get a smoke test done to see where the leak is.
Here is the link for the gas cap, if needed:
AutohausAZ - Gas cap
Disclaimer: Make sure to check the year and model of the vehicle before placing the order.
Old Aug 8, 2014 | 11:27 AM
Glyn M Ruck's Avatar
Super Moderator
+1^
Also. 2005 models frequently suffered a filler pipe crack which causes EECS codes. Smoke test will reveal.
Old Aug 8, 2014 | 06:24 PM
LILBENZ230's Avatar
2019 G70 6MT & 2022 Ford Maverick XL
Yes it was the fuel filler neck in almost every instance I read about on the forum back several years ago. Happened to my 05 as well.
