Whats your RPM's in 5th gear?
Old Nov 28, 2014 | 08:40 AM
Benzomatic76's Avatar
W203 '05 C240 4matic
Hello everyone. Ive noticed that when im doing about 70mph the RPMs hit a little over 3000. Does that sound normal or should i follow some steps i read earlier in resetting the shift points on the trans?
thanks!
Old Nov 28, 2014 | 09:44 AM
neurodave's Avatar
2001 C320 w/ Sprt Pkg
I'm at 2500 RPM at 65, about 2700 +/- 50 RPMs at 70MPH. Looks like you may be a bit higher than me, but I'm not sure if your engine is different, so it may be normal.
Old Nov 28, 2014 | 10:13 AM
Yeah I forgot to mention its a V6 2.6l with a 5 speed auto. I just think that the RPMs maybe a bit too high for that car.
Old Nov 28, 2014 | 10:19 AM
neurodave's Avatar
It may be just about right. It's only about a 300 RPM difference from mine, and I have the 3.2L V6. Maybe someone else can chime in on this, but maybe the difference in horsepower might have an effect on RPMs in the engine. Example, since you have slightly lower HP, it may need to raise the RPMs to sustain the speed you want.
Old Dec 1, 2014 | 04:33 PM
glocati's Avatar
2016 GLE 350
my C240-2.6 w/auto tranny is right at 3K RPM @70MPH.
Old Dec 1, 2014 | 07:48 PM
Cntrypckr's Avatar
2017 GLC300, 2013 C250 Coupe (sold), 2008 CLK 550 Cabrio (sold), 2002 C240 Sedan (sold)
I'm 3000 rpm at 70 mph also. I have read somewhere on here that it's normal
Old Dec 1, 2014 | 09:53 PM
glocati's Avatar
2016 GLE 350
Your slightly higher RPM is probably due to gearing of the 4-Matic. All the same, that is normal RPM range for US Spec 2.6.
Old Dec 3, 2014 | 01:24 PM
neurodave's Avatar
Decided to check today and I am at about 75MPH when the engine is at 3000RPMs. Only different because of the engines.
Old Dec 3, 2014 | 09:55 PM
02C240's Avatar
c240
of course if the road is not level (going up a slight incline) will increase your RPM to maintain the same speed..
Old Dec 3, 2014 | 11:09 PM
lawrencecheng's Avatar
2003 C240, 2016 C300
I have a 2003 C240, at 70mph, my rpms are at 3000. It's quite normal, but it's still quite high.
Old Dec 4, 2014 | 04:03 AM
Thanks guys, at least we know its running normal.
Old Dec 5, 2014 | 02:50 PM
C230 Sport Coup's Avatar
C230 Sport Coup + 2006 W164 ML350 + 99 Ford Escort RIP
6000 Rpm at 155 MPH.
Well, I actually saw a video of a 2002 coupey in italy that was exactly that.
We're limited to 130.
