MJ50's W203 Mod Fever (OEM Retrofits)
Rating: Thread Rating: 5 votes, 5.00 average.
Old Sep 17, 2006 | 12:05 AM
  #351
MJ50's Avatar
Super Moderator
bone stock E55 AMG
Originally Posted by Blake P
PERFECT! Enjoy the ride.
thx blake!
Old Sep 17, 2006 | 12:06 AM
  #352
MJ50's Avatar
Super Moderator
bone stock E55 AMG
Originally Posted by BIGjohnny
Nice! I got the Tein Coilover as well, Super Street. I believe you can go lower in the front but the Yokahama tires will rub against the Coilover. By any chance, is yours at the lowest setting in the front?
I know this because I have the exact same tires with C32 AMG Wheels. These tires prevents me setting the Tein CO at the lowest settings in the front.
NICE job.
i dunno the settings but the front tires did rub the springs.
alternative was to raise the front little bit... but i decided and put on 2mm spacers... hmm, never realized a tire brand will make a difference...
Old Sep 17, 2006 | 01:03 AM
  #353
BIGjohnny's Avatar
/////AMG
Yea, some tire brand are wider than others. When i switched from Michelin Sport to these Yokahama, i had to make three full counter clockwise rotation ( 1/4 to 1/3 inch increase in height) to prevent it from hitting the CO.
I bought some H&R 5 mm spacers, but it caused vibration to the steering wheel. Hopefully you won't run into any problems with those 2 mm spacers.
Old Sep 17, 2006 | 01:09 AM
  #354
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
looks good congrats
Old Sep 17, 2006 | 01:17 AM
  #355
rlee02135's Avatar
2004 C32 ///AMG
nice drop.
i have the same drop with 9" wheels in rear with goodyear f1 gs d2s and it rubs so damn much
Old Sep 17, 2006 | 01:55 AM
  #356
white_w203's Avatar
is SOLD
car looks better already. very clean. lot of oem mods too
Old Sep 17, 2006 | 02:32 AM
  #357
MJ50's Avatar
Super Moderator
bone stock E55 AMG
thx every1
Old Sep 17, 2006 | 02:59 AM
  #358
powa's Avatar
C320 Coupe
very nice drop! once i done all my mod i might go for tein basic CO too =)
Old Sep 17, 2006 | 09:06 AM
  #359
c230 o5's Avatar
BMW 135i
So if i were to get the pss9 coilovers there going to rub against my tires???????????? if they do how do i stop that from happening
Old Sep 17, 2006 | 12:03 PM
  #360
Blake P's Avatar
'09 A4 S Line
There is no way to know until you do it. Not all coilovers and wheels are the same. Different coilovers have different struts and springs. Different wheels have different offsets. Different tires have different shaped sidwalls. All of this goes into determining fitment and potential issues. The only thing you can do is add spacers once you determine if you're rubbing. I suggest you do the research first before deciding on a coilover setup.
Old Sep 17, 2006 | 01:34 PM
  #361
Ryanr317's Avatar
R129, XF Sportbrake, SC400
mj50, did you already sell your cup kit?
Old Sep 17, 2006 | 03:43 PM
  #362
MJ50's Avatar
Super Moderator
bone stock E55 AMG
not yet...
Old Sep 17, 2006 | 04:03 PM
  #363
Sanny's Avatar
06 Granite Grey c230
who did the install for u?
i went to usc too, class of 04
Old Sep 17, 2006 | 05:50 PM
  #364
drexappeal's Avatar
Super Moderator Alumni
Midnight Blue 2004.5 C230 Kompressor Sport Sedan. 2002 w210 E320, 2009 w211 E350 Sport
Glad it worked out, mj. Replied on the other forum too, but thought I'd reply here also. PM me and let me know how your experience was.
Old Sep 17, 2006 | 10:14 PM
  #365
MJ50's Avatar
Super Moderator
bone stock E55 AMG
it was a shop drex hooked me up with...
gotta go back next week to find out if mine was set to lowest settings...
i was too excited & forgot to ask...
Old Sep 17, 2006 | 11:07 PM
  #366
BlackLiquorish8's Avatar
C3Twon AWD Jumpofffff
looks sweet does neone know if TEIN makes nethin for the 4matic sedans???
Old Sep 17, 2006 | 11:22 PM
  #367
B189s's Avatar
1996 MB E320 & 2010 Nissan Elgrand
NICE! I bet the ride is OK too since you only have 17's. BTW, did you hear any noises/sounds after the installation? It's just I have this weird knocking sound after my Tein CO was installed and my shop cannot find where the sound comes from. Anyway, Enjoyyyy!
Old Sep 17, 2006 | 11:40 PM
  #368
MJ50's Avatar
Super Moderator
bone stock E55 AMG
i did hear kinda like humming noise from the front right when i first drove it after the install... put 2mm spacers on the front and now it's ok.
Old Sep 18, 2006 | 12:03 AM
  #369
B189s's Avatar
I actually want to lower the fronts a little more, but I don't want to use spacers to avoid vibration. It's enough vibration for me from the spacers I have for the rears. Also, my rears are already at the lowest, but it's not even low. Still have 1 1/2 finger gaps on the rear, so it's pretty much 1 1/2 finger gaps all around in my car. Do you still use your spring pads on the rear?
Old Sep 18, 2006 | 12:44 AM
  #370
BIGjohnny's Avatar
/////AMG
You can simply check my removing your front wheels. I'm sure your back is set at the lowest setting. However, the front i believe you have another inch to go.
Old Sep 18, 2006 | 01:36 AM
  #371
Blake P's Avatar
'09 A4 S Line
Something is definitely not right. There should be no gap in the rear at the lowest setting, with the tread of the tire tucked in the fender (check the pic in my signature). Maybe you're confused and it's actually at the highest setting instead? No spring pads should be used with coilovers.
Old Sep 18, 2006 | 05:42 AM
  #372
drexappeal's Avatar
Spring pads should have been removed in the rear.
Old Sep 18, 2006 | 01:58 PM
  #373
B189s's Avatar
Blake/Drex : I did ask the installer regarding the spring pads and he told me
spring pads are needed, so that no noises/sounds will be
produced by the suspension. Is that right? In fact, I do have
this knocking sound with the pads still in the car. Perhaps, I am
not supposed to use them and the the knocking sound will be
gone . Any idea?
Mj: Sorry to hijack your thread!
Old Sep 18, 2006 | 02:23 PM
  #374
Blake P's Avatar
'09 A4 S Line
gone . Any idea?
I am 100% positive you should have no pads, so the installer is full of it. Once the spring pads are removed you will have the desired drop and the knocking will be replaced by the sweet sound of women "oooh"ing and "aaah"ing.
Old Sep 18, 2006 | 04:16 PM
  #375
B189s's Avatar
Thanks Blake LOL. I will see if I can have the pads removed ASAP.
You have already rated this thread Rating: Thread Rating: 5 votes, 5.00 average.
