MJ50's W203 Mod Fever (OEM Retrofits)
#80
2002 c230 sport coupe
So mj50, you used #4pads all around or just in the rears? And I'm assuming that's to make it more even with the front? Sorry, a little confused about the pads.
Also, where did you get it installed if you don't mind me asking. Thanks.
#82
Super Moderator
![](https://staticssl.ibsrv.net/autocomm/Content/MB/mbwambassador2.gif)
bone stock E55 AMG
i used #4 pads for the rear... there are no spring pads on the fronts... yes, if u don't change the pads, the rear will have no gap while the front does... i got mine installed at TWS...
#83
Super Moderator
bone stock E55 AMG
haha...
i may get flat badge and CL grille later, but i like the star right now...![Smilie](https://mbworld.org/forums/images/smilies/smile.gif)
Originally posted by AMG BRED
very nice.. now get a flat MB badge and a blacked out grille.
#84
![Wink](https://mbworld.org/forums/images/smilies/wink.gif)
#85
W209
Looks good. I thought the cup kit would lower the car even more, but you do have very thick spring pads. are you planning to replace the spring pad anytime soon. I would look awsome if the there are no gaps between the tires and the fenders. But it looks good already.
#87
Super Moderator
bone stock E55 AMG
actually i like the drop now...
not too low and still sporty...
pretty good ground clearance...
i hope the springs won't settle down too much...
#94
1 Post
CLK500/Range Rover HSE/E55 AMG/Bmw 328Xi coupe/BMW 4.8x/Bmw 335i/GS350/Audi S5/E350
Any of u ever head of I-bach springs...i heard that will lower your car in the front about an inch or so....any thoughts?
#96
C230k sedan
Originally posted by vadim
Pad #4 is the thickest. To lower it more, one needs #1.
i was wondering though, if it's possible to put #1's in the front and #4s in the rear? to give it a better stance...(the front is a little bit higher than the rear)?? any pictures with the #1's all around?
thanks in advance
#97
Super Moderator
bone stock E55 AMG
there are no front pads for w203...
Originally posted by C-hris ClasS
Nice ride,
thanks in advance
Nice ride,
thanks in advance
#98
C230k sedan
sorry i misread the settings..im thinking about lowering mine...but for some reason i want the front to be a little lower than the backs? any suggestions for me..i like h&r's tho..
so the rides pretty much stock?
#99
Super Moderator
bone stock E55 AMG
only with coilover, u can drop front more...
yes, cup kit rides like stock...
