04 C230 Rim/tire question
Old Nov 30, 2014 | 12:00 AM
AT_Viper's Avatar
2004 C230 Sedan
My current factory setup:
Front: 17x7.5 with 225/45/17 (25")
Rear: 17x8.5 with 245/40/17 (24.7")
I have the ability to pick up a second set of rims (18x8 that came off an 06 C230) but want to make sure fitment will be ok. I am more worried about negative effects caused by going from a 7.5 to 8 or 8.5 to 8. The overall height can be managed.
My potential future setup:
Front: 18x8 with 225/40/18 (25.1")
Rear: 18x8 with 225/40/18 (25.1")
I have stock suspension and no body modifications.
Please let me know your thoughts on the following:
-Will the 18" rims rub on the inside of the well in the front? (7.5 to 8)
-Will the car suffer or could problems arise from going from 8.5 to 8 in the rear? (Obviously, traction/handling would be reduced)
-Would a different tire size be more appropriate?
-Am I missing anything? (I do not know the offset of each rim although I believe the 18" rims are E35's.
Any and all constructive comments are much appreciated.
Thank you,
AT_Viper
Old Nov 30, 2014 | 04:27 PM
AT_Viper's Avatar
2004 C230 Sedan
No one has any insight?
Old Nov 30, 2014 | 10:05 PM
AT_Viper's Avatar
2004 C230 Sedan
Update on the potential rim size.
They are 18x8.5 not 18x8
Old Dec 1, 2014 | 11:13 AM
krazzdav's Avatar
Veteran: Marine Corps
2017 GLA 250, 2011 C63 P31 (p30 w/ lsd) (in repair), 2005 C230 Sport Eurocharged, 2003 C320~sold
If it came of a w203 they will fit on a w203 as well.
Old Dec 1, 2014 | 12:15 PM
AT_Viper's Avatar
2004 C230 Sedan
My concern is that I dont know if anything was rolled or shaved on the vehicle they came off of. According to all of my research, the rims should be ok but I would be great to have feedback from someone with a C230 with 18x8.5 rims in the front.
Thank you for your input.
Old Dec 1, 2014 | 12:30 PM
krazzdav's Avatar
I am running 19x8.5 in the front of my stock 03 C320 Sport with no issues and 19x10 in the rear. The rears I need to trim the bumper tab though.
Old Dec 1, 2014 | 12:38 PM
krazzdav's Avatar
scour through these threads for peoples setups too
https://mbworld.org/forums/c-class-w...nt-thread.html
https://mbworld.org/forums/c-class-w...re-thread.html
Old Dec 1, 2014 | 01:22 PM
AT_Viper's Avatar
2004 C230 Sedan
Thanks for the advice but I had search both of those threads first. Most people had done suspension/body mods in those threads, nothing stock.
What size rubber do you have on those?
What is your offset?
I was worried about the 8.5 from a 7.5 on the front but you are running pretty large rims on the front so I think I'll be ok.
Thanks for the help.
Old Dec 1, 2014 | 01:51 PM
krazzdav's Avatar
You want to get tires that are as close to the stock tire height as possible. I went from a 7.5 all the way around to the 8.5 +30mm in the front and am running 225/35x19 They are stretched a little too much for my taste though but the rims sit nice and flush to the outer fender Next time I will go a tad taller and wider so they fit better on the rims...prob a 245/30x19. There's lots of good tire/rim calculators out there that can help you out.
Old Dec 1, 2014 | 02:20 PM
AT_Viper's Avatar
2004 C230 Sedan
Yeah, I was thinking about going with 225/40/18's all the way around. I have calculated hundreds of combinations 35 profile's are rather pricey hence the 40. I am relatively close to my stock overall with the 225/40's.
Old Dec 1, 2014 | 05:51 PM
phister's Avatar
06 C230 SS 6spd
You'll be perfectly fine with 8.5 in front. Most upgrade to 8.5 in front. The concern is offset not the width. That's when you most modify to fit is when they start to run offset more negative or closer to 0. On our cars you can run between +38 to +25 offset without having to do any modifying.
Old Dec 1, 2014 | 11:03 PM
AT_Viper's Avatar
2004 C230 Sedan
I believe my current rims (stock) are 35 offset the potential rims are 38 so increasing in the opposite direction that I wanted to go.
Phister, what are you running on your c230? (rims/tires)
I don't really like the look of the stretch but am trying to have a set of backup tires in the event I need them. Key thing is that the rubber is affordable (<$100/tire) 225's I am afraid are too "stretched" for my liking on 8.5 rims.
Old Dec 2, 2014 | 12:52 AM
phister's Avatar
06 C230 SS 6spd
225/40/18 on a 8.5 i would hardly call any stretch heres how it looks like
You dont want to know my setup cause I'm pretty crazy on stretch and width
my old setup was
18x10 +2 215/35/18
18x11 +4 235/35/18
currently i'm working going widebody on the car now with a crazy setup
18x11 -48
18x12.5 -37
Old Dec 2, 2014 | 09:51 AM
AT_Viper's Avatar
2004 C230 Sedan
Thanks for the picture, it helps a lot. I looked through Google images but there are so many and many are not 225's stretched over 8x5's. I was second guessing myself I guess.
Thanks for all the help guys! I'll post pictures after everything is complete.
Old Apr 1, 2018 | 07:42 PM
Dalton Edens's Avatar
Mercedes Benz C230 Sport
my old setup was
18x10 +2 215/35/18
18x11 +4 235/35/18
18x11 -48
18x12.5 -37
Phister, so I have a 2006 C230 and am looking to put aftermarket wheels on it. I'm wanting to do the same setup with the 225-40R18 with 18x8.5 32mm or 35mm as the offset. That would work on my car for sure with no issues? Nor spacers or any adjustments? Thanks!
Dalton
