will SLK230 AMG's fit a 2004 C320?
Old Jan 13, 2004 | 09:57 AM
dc2774's Avatar
Tried to do a search but ended up with no results. Any help would be appreciated. I believe the wheels came off a E class.
Old Jan 13, 2004 | 11:07 AM
Lynn's Avatar
SLK, CLK, W210 E, and C wheels are interchangable.
Old Jan 13, 2004 | 04:13 PM
dc2774's Avatar
Lynn, is it the same for 2001 SLK230 - those wheels will still work on my C320?
Old Jan 13, 2004 | 04:50 PM
tifosiv122's Avatar
SLS AMG | S65 AMG | GL550
He just said the SLK and the C are interchangable. Yes.
Erik
Old Jan 13, 2004 | 10:32 PM
Lynn's Avatar
All W202, W203, W208, W209, W210 and R170 wheels should be interchangable, unless the car has the big brakes, then only the 17" wheels can be used. W211 E class wheels do not fit the above.
Old Jan 14, 2004 | 02:40 PM
Virect's Avatar
Question
Here goes the stupid question,
Does the 124 and/or 126 series (or other model) 15 inch wheels (alloy or steel) fits on a c230 coupe?
In facts i'm looking for 15 inch wheel for winter use and rather have mb alloy wheel.
PS: I know that the w202 steelies fits but what else?
Old Jan 14, 2004 | 03:00 PM
tifosiv122's Avatar
Do a search. I swear I remember someone putting 15" rims on his coupe last winter...I might be nuts but I am almost positive.
Erik
Old Jan 14, 2004 | 03:01 PM
tifosiv122's Avatar
Here I found one post...
https://mbworld.org/forums/showthrea...ght=winter+rim
taylor192 - I have 15" steel wheels from a 1999 C-class on mine right now. The offset is 35 mm compared to 37mm, and no problems, just looks realy tight around the front calipers.
So I think your OK with the 15" size...
Erik
Old Jan 14, 2004 | 04:50 PM
Lynn's Avatar
I don't know if W126 or W126 wheels will fit. Try asking Luke@Tirerack over in the tire forum.
Old Feb 1, 2004 | 11:45 AM
dc2774's Avatar
Sorry, will 2001 S-Class 18" rims fit on a 2004 C320? Are the offsets correct?
