Any idea what is the normal Timing advance for 2005 C230 M271?
Old May 16, 2015 | 12:55 PM
ramy_maurice's Avatar
2005 c230
My car runs a bit rough when i start it and there is barely noticeable hesitation when I start accelerate at low speed.
I used an obd scanner to get the timing advance readings at idle and it was varying between +4.5 to +8.
is that normal?
Old May 20, 2015 | 04:42 PM
RWDlifer's Avatar
2005 C230K SS
checked a while ago, between 8 and 12 at idle with engine at operating temp. Never went below 8.
Old May 29, 2015 | 07:46 AM
2005 c230
Thank you, any idea if that would be Timing chain issue or cam shaft sensor issue, I have no check engine codes.
Thank you again.
Old May 29, 2015 | 12:34 PM
RWDlifer's Avatar
2005 C230K SS
I would pull the valve cover and check...chain should be taut across the upper guide. Also check the sprocket teeth. Type "my chain pics" in the search box and dig up my post with pics of what it should look like. My chain was barely stretched at 120k miles, replaced it anyway.
Old May 29, 2015 | 02:19 PM
2005 c230
Thank you for the help, much appreciated.
Old Mar 22, 2023 | 11:27 AM
autospeed_bg's Avatar
Mercedes
For me with a new chain it is -17 ? Any ideas?
Old Mar 23, 2023 | 01:24 AM
tkid's Avatar
C230K M271 CL203 2003 model
This is what i get during a normal drive.. 20 year old chain, may have a bit of slop??...
Old Mar 23, 2023 | 04:32 AM
Mercedes
@ tkid , when working on site, warmed up car. After chain change TA is -17. Before it was -12.
