pulling to the right? was it fixed.. if it was..please give details
on top of that..the other dealer had already aligned it 1 time .. so this dealer tried to make me pay for it since there is only 1 free alignment.. i was like..shizzle ma nizzle..
i didn't pay for the pull to the right option... so i shouldn't be charged.. i argued for an hour and finally they removed the charge....so if any one had this problem before... please be kind enough to pull out your receipts to see what they did.. i know alignment is not fixed my problem.. there is something else that needs to be done....
Neil
My receipt does not say anything useful on this issue. I'm sorry. Next time I'm in for service, I'll ask. I'm now on a first name basis with the Shop Forman and the Service Manager.
I'm not one to encourge law suits, but have you looked in the a lemon law case if you car is seriously pulling. Usually the same issue needs to be fixed 4 times with no improvement to have a strong case.
Good luck!
Beth
Most cars do pull to the right because the road surface slants that way for drainage. Find a perfectly level road like an runway at a local airport and see if it still does that.
i did drive the loaner and it drove absolutely straight..i was expecting it to pull to the right as well but it was just fine on the normal roads that i drive on... so using that as a basis, i drove my car on those exact same roads the loaner went straight in and it pulled to the right... i might go as far as saying that it is pulling to the right more than before...but that may also be in my head.. but it definitely is pulling to the right...
406560 Wheel Alignment - Front and Rear, Check and Adjust...
322050 Front Stabilizer Bar, R&R/Replace if required...
406716 Frt. Wheel camber/caster -L/Side (Install kit if nec.) adjust.
They found my front end out of alignment, and they "8845 - aligned R&R Frt Sway Bar and replaced an L Caster Bolt." The car tracks fine, now.
...This is the 3rd time i have taken my car in to fix the problem of pulling to the right. this last time, they just aligned it agian and it still pulls to the right on all road surfaces except on the left most lane...
it's annoying coz they make it sound like this is the first they have ever heard of this problem and that I must be nuts.. they never say that this is a known/heard of issue with the C...
