Oil Level Question
Old Jul 6, 2015 | 03:00 PM
bobinyelm's Avatar
C320, SLK230, T1N Sprinter
Oil Level Question
2003 C320 Wagon
On my most recent oil change, I drained the oil via the pan bolt, then replaced 8.5qts 0W-40 Mobil One as always. (One 5qt M-1 Euro container plus all but 1.5 qts of a second 5qt container using the lines in the jug).
About 10 miles later, I got the "red screen" warning to drain oil, which I have never gotten before (I re-read my owner's manual and I didn't even see it mentioned).
I did some research, and sucked out 8oz via the dipstick tube, and it then said "Oil Level OK" when cold.
I drove it 10mi and the "overfilled-drain oil" came on again. I let it sit an hour while I was in a store, and checked it when I came out, and it said "Oil Level OK" and the drive home didn't set the warning again (yet).
How much OVERfull does it take to set off the warning?
I understand that right "at the full line" the oil expands a bit and might trip the sensor, but I drained it well when I changed it, so I doubt much was left in the pan. The engine was not very warm when I drained it this time, but the ambient temp here was 95 degrees (oil was very thin), and I waited a few minutes until the drips stopped.
I know the proper level is 171mm from the bottom of the oil pan, but I don't have a MB dipstick. I tried a piece of bailing wire as a dip-stick substitute, but it's hard to measure because the tube wipes oil onto the wire on the way out.
Given it happened AFTER the oil change, I don't think the sensor suddenly went bad (too much coincidence), so for now I am assuming the oil level is screwed up, and that the sensor didn't decide to go bad at the SAME time.
Old Jul 6, 2015 | 05:36 PM
samaritrey's Avatar
Super Moderator
THE C350
For some reason I thought the c320 only took 7.5-8quarts of oil what does the manual say?
I would do a manual measuring either buy the MB dipstick or figure out a way to measure it properly.
Have you done the oil changes on this car before?
Old Jul 6, 2015 | 09:53 PM
bobinyelm's Avatar
This thread says 8.25-8.5qts if the oil was drained at the pan, and 7.5 qts if sucked out of the oil dipstick tube:
Click on: https://mbworld.org/forums/c32-amg-c...us-quarts.html
Yes, I have done my previous oil changes using same Mobil 1 0W-40 Euro and same filters (I bought a dozen when I bought the car).
I should now have 8.25 added quarts (8.5 qts - 8 oz).
Maybe if I get it again I'll drain another 8oz.
But to be honest- I didn't look at the manual this time. I just verified online to confirm my memory I used 8.5 qts last time.
Strange because I am sure I added 8.5 qts previously w/o the warning light.
Old Jul 6, 2015 | 11:52 PM
samaritrey's Avatar
Super Moderator
THE C350
Yep just verified it is 8.5quarts I must be loosing it...
Have you checked the level with dyno mode? curious what it says before you start on level ground and after the warning comes up.
Old Jul 7, 2015 | 10:32 PM
bobinyelm's Avatar
I drove the car again today and after 10 miles the "drain oil" warning came on again.
I let it sit for about an hour while I attended to a chore, and checked the oil electronically when I got back to the vehicle and the engine and cooled. It said "engine oil level OK," and the light did not come on again on the way home.
I suppose it is possible I did not drain every drop of oil out of the engine, so what was left in it plus what I added created and overfill condition. I don't see how very much could've been left in however because I let it drain in till it was down to an intermittent drip out of the pan.
I will try sucking out another 8 ounces leaving 8.0 quarts added and try again. That is still a very safe level.
